Curious about an earlier discussion regarding cell level fuses and inline fuses. Could a 200 amp fuse go inline between the two halves of the pack to potentially isolate one side?
Will install one between batt and ESC and charge port.
Changed my mind and going top mounted… I am ordering the battery’s later today 12S8P 18650 30Q brick style pack. Could somone check this wiring diagram and see if there is a problem ?
Be carefull with the LLT i installed it on a battery, and didnt disconnect the balance wires from it,and by the time it got to my customer the cells were at 2.8v and thats on a 18ah pack…
Thats a fair price if you ask me, would happily pay that for such a solid product
On some project Im working we are using a 550€ bms from EMUS on each battery, because there are no other options that have all the functionallity we need, and thats totally acceptible price wise
I installed 3 Neptune 15 so far, when you get one in hand and feel it you will be happy you spent the money on it haha, even the cables are sillicone and are long compared to crappy pvc/whatever we usually get on a bms
Also you can use the bms up to 15s which is great as well if you decide to go up a few volts when these new vescs come out
And the app is great as well compared to xiaoxiaing for example
It’s been a while since I looked but the thing that queered me off was how the technical discussion went with the vendor on ES. And the price ended up kind of high at the time.
Iirc there was also some question about the accuracy (not precision) of cell voltage measurements, but tbh I’d guess it’s at least as good as the LLT stuff…
One big advantage of LLT is the serial protocol has been documented, so you can do cool stuff over btle (or ttl hardwired)
Didnt see any of the discussion topics on it nor checked the precision honestly but its using higher grade components than llt for sure, the soldering quality on the eye looks as good as it can get as well
Not sure about the serial protocols but who is using that anyways?
On the app you can change basically every setting on the bms, not as many compared to LLT in the destkop app but it has the most important stuff in there
Honestly if I had the money I would use it, especially if you cant get your hands on a flexibms
