I have a pack that’s divided into two sides of about 80mm (max) in width, so a total width of about 160mm. I want to put shrink wrap (lay flat) around each side individually. The pack has a height of about 18mm.
What size flat heat shrink wrap do I use?
Thought about using this but don’t know what size.
Ah thanks! I meant both sides individually so calculated it myself, (80 + 20) * 1.1 (and 1.5) = 110-150 mm so I will try to find a size somewhere near those numbers.
First Battery Build - 12S 7P Samsung 30Q - Cells ordered from Liion Wholsale and delivered in 2 days.
I assembled the p-groups with neutral cure silicone and welded the nickel strips with a K-Weld. I used a mix of either 3 12 AWG wires or 2 10 AWG wires on the series connections because I didn’t have enough of either wire to do them all the same, but I doubt the electrons will care. I didn’t get a photo of the balance leads before I secured everything down but I made sure to run them individually and not cross any wires. I am using the LLT smart BMS for charge only and a charger port capable of handling 45A although I have it installed on a 6 amp charger. Shrink wrap will be here Friday, but I still need to peel back some of the Gorilla Tape to install the battery temperature sensors. I learned 90% of what I know about battery building here and on the old forum. Thanks to everyone here for sharing the knowledge
Thanks for the advice. Unfortunately unless I significantly change either the pack layout or the enclosure, I’m limited to cells 65mm long - They’re assembled laterally, so any increase in cell length will result in a pack that doesn’t fit, unless I do a complete redesign.
Friendly reminder to buyers of batteries: seeing readouts of mains voltages, individual p-group voltages, a few of the packs spot-welds, and even a short video of Dremeling a small portion of the nickel for purity can save you a whole lot of pain.
I found out a certain reputable battery builder was using some steel infused nickel for some amount of time… hopefully it never ends up mattering 🤷
Ordered kapton tape and it was terrible, wouldn’t stick to anything, not sure if the stuff I ordered was typical of kapton tape or just cheap junk. . I started using the gorilla tape to keep the balance wires neat and in place and the next thing I knew the whole front of the pack was covered. I learned a TON while building this pack and there are definitely a few things I will do differently on my next one, but I feel confident that this will be safe and reliable. I can say for sure I hugely underestimated the amount of labor that goes into building a battery of this size, when I was first looking at what quality battery builders charge for a pack the pricing seemed high to me. Now after making one for myself it seems like a bargain. I totally enjoyed the process though and look forward to the next one, I have a huge roll of guerilla tape!
Kapton tape is not as sticky as some other tapes, but has high dielectric strength (prevents arc through). Gorilla tape is really sticky except the glue will melt and run with heat from the battery, the mesh of duct tape fiber is also easy to puncture by sharp objects. Recommend using fish paper for tough insulation purposes, use double sided tape or whatever means to secure the fish paper, then finish off with harness cloth tape for wires and shrink wrap after.
I was not thee who possessed said impure nickel, only he who tested and found its impurities. I hear there is one who plugs leads of expensive battery into each other to go poof who may know more on the matter, if they so wish to comment. Else; I’ll refrain.
