That’s an unfair conclusion IMO.
So far we only have a couple Samsung cells recommending a V-0 flammability rated enclosure for esk8 (and similar size packs). It would help if you could check if that’s true for the rest of the Samsung’s used by the community.
But that’s just Samsungs. There’s no similar recommendation from any other cell brands AFAIK.
While one could argue that having a “must quench flames in 10 seconds once flame is removed” flammability rating for any battery pack enclosure might help we have to realize that the deck could contain the fire for a much longer period than a V-0 rated (and therefore plastic) enclosure would.
So is it fair to judge the community for not having the deck be made from V-0 rated materials?
Knowing how a V-0 rating really applies to our application and how other non-rated materials perform during a pack fire is really important. Just having a certain rating often doesn’t mean much. For example, those Samsungs have a UL rating but it’s still recommended to put large Samsung packs in a steel box.
And a UL94 flammability rating like V-0 is only for plastics. It can’t apply to aramids like Kevlar and wood decks. Other ratings/tests need to be used. Kevlar is indeed fire resistant but will melt, other materials in cloth form are essentially fireproof.
I meant extremely low voltage. I’d like to see cells cycled to whatever minimum is posted in their data sheets. Samsung cycled from 1v to 4.2v and others from 2v to 4.2v. What else would be worth looking at other than temp, capacity, IR (although I imagine it goes hand in hand with temp), deformation, self discharge,…? I’ve never seen such a test. Could use the crappiest used cells that were going to be thrown away anyway
I was thinking of doing the test myself and think the fireproofing wouldn’t be too hard but should have a high power “smoke catcher” attached just in case, no?
If looking for a way to improve safety it seems an easy place to improve
Nomex is cheaper than Kevlar and shows better fire resistance. Could line the battery easily with the fabric or even use it in its honeycomb form as a core in a composite deck and be light too.
I’ve never seen a deck on fire first hand but in videos the enclosure falls apart and the cells fall out. Ideally it would all hold together with cells contained so you could move it somewhere it could burn more safely.
Fiberglass is amazingly fire resistant, but when it is impregnated with epoxy, or polyester resin to form a solid structure, it is not…
Kevlar, the same.
“The SAERTEX LEO SYSTEM is being used in the floors of 66 ICE Version 3 high-speed trains in Germany, cutting weight by 50% versus previous plywood panels”
What does “cycled” mean to you? A single discharge or a repeating series of discharges typically used to determine cycle life?
I ask because for me if a cell was cycled then it was repeatedly discharged, as is done for cycle life testing down to 2.5V. Otherwise I would say it was discharged to make clear it was done only once.
So for me none of the cells have been cycled at those overdischarge voltages and is why I’m asking to make sure I understand you.
I’m not sure for what purpose you’re asking about this. What to monitor when doing testing (and after) to try to determine degree of risk (or something safety related)?
Monitor deformation? For bench testing?
Are you talking about the steel cans deforming solely due to being discharged to a low voltage?
You’ll never catch the smoke. At best you can re-direct it.
Up to 2 liters of smoke/gas is created by every Ah of a cell in runaway. That’s up to 10 liters per cell…too much to trap.
You’ll need to direct the verrrrrrry toxic gases and soot outdoors or, better yet, do the testing outdoors. Hard to overstate how nasty this stuff is.
One…I’m not sure the existing deck materials are a safety issue but I’m looking forward to hearing why you think they are.
Two…it won’t be easy. There are a limited number of affordable materials that can function reliably as a deck.
Sure sounds like the deck isn’t a safety issue if this happens.
All staying together would definitely be preferable. To survive intact until runaway is done is a verrrry tall order though. It could be half an hour before the last cell catches fire though some packs completely burn in a minute or two.
IMO a single wrap with mineral wool (or similar fireproof material) just won’t help enough. And there’s often barely enough room, or none at all, for adding that little bit of material.
Cool stuff but I’m certain it costs a fortune. IMO, exotic materials just aren’t needed until we show that existing decks present a hazard or prevent moving a board with its pack in runaway outdoors.
Is it better to just delete what the mods/admins feel is misinformation (and all the replies/comments) or might it be better to leave the original post and the replies that explain why the original post was wrong?
Just deleting the post means we’ve lost an opportunity to educate. We’ve lost an opportunity to address something that others might have been thinking (or doing) too.
Just wondering out loud to see what others think, no real correct answer here.
Friends, I think there’s a key point being missed in our discussion about cell “revive-ability” (as I call it in my internal dialogue).
When cell manufacturers post specs on a cell’s data sheet, they describe the voltage from which a cell can be revived, as @hummieee has noted. These values are usually very low, much lower than what we’d typically consider a “safe” voltage to attempt reviving a dead cell.
The important thing to understand is that this value describes the cell’s voltage during extreme and temporary voltage sag, not the nominal/resting voltage. So, when a data sheet states that a cell can be revived from 1V, it does not mean that if the nominal/resting voltage is 1V, it’s safe to revive.
Why does this happen? If manufacturers said, for example, “the lowest voltage we’d recommend charging from is 2.8V,” designers using the cells in products would be out of compliance (and liable for issues, fires, etc.) any time temporary voltage dips occur due to heavy draw, which is normal in many use cases.
(edited to reflect @Battery_Mooch 's feedback which I appreciate!)
Does this make sense to everyone? @hummieee@jack.luis, I think this might be at the heart of your disagreements. @Battery_Mooch, could I humbly ask you to review what I’m saying here and correct me if needed?
Boring but necessary disclaimer: Everything involving batteries carries tremendous risk. Never attempt anything you don’t fully understand.
i think the hardest thing about this though is that ifeel most would look for the answer, see the first thing, and go with it and dip without reading further, or
would see our uh
discussion, dip out and either wing it or look at a potentially worse forum for information
in this case i would purge the whole thing, and then in place of it have a maybe new thread where the basic info that covers faqs n all that jazz of the current accepted practices are at the very top of the thread, and is updated regularly with whatever discussions below
I think our goal as a community is to make sure that inaccurate information doesn’t proliferate. I agree w you @Battery_Mooch - if we yeet every incorrect assumption folks express, we miss the opportunity to educate others who might have also held the same incorrect belief. This is an environment for debate, and that requires an exchange of beliefs that conflict sometimes.
One thing I love about our community is that wholly incorrect statements rarely go unnoticed. Quite the opposite, in fact!
The only posts in this thread that are useless are the ones that are just insults and add nothing.
A debate only adds value and ideas that may have just been dismissed before. In this case most everyone is saying yeah, charging a cell that’s at 1v is a terrible idea, but not everyone on the internet knows that. Now there’s a lot of back and forth showing why, why remove that? This thread is already 25k messages deep. No one is reading the whole thing to be enlightened on how to build batteries safely. Also if someone reads one reply that is disputed by many people, and assumes it’s accurate, they were going to build an unsafe battery anyway
I respectfully disagree….
The manufacturers require a BMS that shuts off the discharge if the cell drops to 2.5V (or near that). It can never reach too low a voltage under load (beyond perhaps a short delay after it crosses the undervoltage threshold).
The only way the cell can drop to below that is because of parasitic current draw (from the BMS or other electronics) or self-discharge when not being used. IMO the datasheets refer to resting voltage for the overdischarge thresholds, not the voltage under load.
I think this thread can still be the go-to resource for battery-related stuff. But it needs a different title to better describe its purpose and 23,000 posts (not exaggerating here) need to be deleted.
No one is going to read this insanely large thread, the signal-to-noise ratio is wayyyy too low for all that work.
Cleaning this enduring thread is a huge, thankless task.
How about locking the thread, starting a new, titled it something along the lines of:
’ Best Esk8 battery building practices and battery care, as of May 2024’
The standards of build quality are higher here.
Standards should be higher here, as the abuse potential is higher than any other I can think of. Flex, extreme vibration, a tightly packed enclosure with other items witbin also producing heat., asking as much as a cell can deliver…
Link relevant posts from this locked thread.
Start anew.
In my opinion that’s exactly what this thread is intended to be and it does all of that pretty well but generally functions more as a chat room than a wiki.
It would take a lot of work but it might be worth starting a separate thread for more concentrated, peer-reviewed information, while leaving this thread as an (I think appropriately named) discussion space.
