The battery builders club
that one guy is Galileo and the rest are the church? :stuck_out_tongue:
i think this thread didn’t benefit from personal attacks, it put people on tilt and degenerated the conversation.
I think @hummieee started out with some lower than usual voltage salvaged cells and was exploring ways of knowing better how much risk was involved recovering them and what tests might be done.
I think @Battery_Mooch described ways in which it’s really hard to know.
@hummieee was exploring if there’s discharged way to low voltage number you can use to aid in the effort of sorting salvage cells. the group points out the usual 2.5v discharge number in the datasheets. and @hummieee points out some of the datasheets mentioning charging procedures (ā€œpre-chargeā€) for cells below 2.0v. (and as low as 1v, though i didn’t see that one) It’s curious that these procedures are in there. and that any noob can read them. So it’s worth our discussion how to interpret them.
by this point everyone is on tilt and generalizations are getting worse. and everyone’s generalizations are getting hyper picked apart. forum could do better here.
The group seems to want to express to @hummieee that exploring that type of understanding might document procedure considered generally unsafe. ( read as, outside the normally accepted levels of risk ) and i think there’s a reasonable point there, but we’re not making it super clear.
@hummieee, when someone asks me is something is possible, and it’s outside the normal realm of saftey. (ie general group risk tolerance) I think good common caveats are, This choice involves increasd risk, you should understand the risks you’re absorbing before going down this path… you could burn you and yourself down, ā€œDon’t try this at homeā€ is a classic. You see those types of statements on all sorts of people exploring outside the edge of commonly accepted risk.
I hope this thread can settle back down some.
but I appreciate @Battery_Mooch and @hummieee’s discussion so far. I thnk it’s valuable.
:yawning_face:. Gets tiresome. I asked u specifically what u wanted me to change in what I wrote. What more u want?
If you have a fire in which no human or animal is hurt, and it’s due to a revived battery of yours, I will laugh. You would have deserved it.
The data sheets say both. I’m not the data sheets and if u have a problem with them keep ur rage directed there.
the datasheet isn’t everything…
see: @Battery_Mooch cell testing
Datasheets are not a replacement for intelligence. Sorry but no matter how many times you jerk off to the datasheets you’re still an misinformed amateur with little chance of improvement.
Yea you already said multiple times.
edit. sent to soon. updated.
I don’t believe he is testing to extreme discharge. The manufacturers surely are though.
you completely missed the point
there’s the current capabilities that the datasheets claim the cell is capable of, but testing from mooch proves otherwise in the real world
we don’t live in a world where we run our batteries in perfect lab controlled environments
What is ur point? Don’t just talk about a point and make it.
@jamie @longhairedboy
This thread. Please. Clean it up.
One moment you’re crying the next ur cursing. Get ahold of yourself. Don’t litter the thread with the same stuff.
If u folks want to go on and on about the same old news in the data sheets… it’s old. It’s been said. If u have something new to add I’m happy to read it.
says guy who keeps referring back to the datasheet
I do believe what the data sheets say are the end all and be all, and if instructions that are given there to charge very low voltage cells are followed, it’s safe. I don’t believe the manufacturers are putting allowances in the data sheets that are too risky to do, and definitely not too risky to talk about.
Jesus fucking christ.
Go charge your batteries at 1V already and leave the forums alone.
Most enclosures on the market are made of fairly fire resistant materials as is, and getting a steel tub is, lets be honest, impractical, bulky, and heavy.
Taking further measures would be seriously impractical, whereas telling someone you shouldn’t charge from 1v is effectively free and very easy to do.
I think eskate would probably fall under the ā€œscooterā€ category on the data sheet and would need v-0 rated stuff to house the battery. While some abs is v-0 the other side of the enclose being a wooden deck likely doesn’t fulfill the data sheet expectation. I’m guessing simply lining the deck with kevlar would pass the test.
Samsung pg 13
Umm…for my Patreon supporters I recently tested a 21700 at 50A-125A continuous. I’m thinking that’s pretty damn extreme.
There’s actually no reason for the manufacturers to test at levels this high though since it’s above the rating and significantly increases the risks of using the cell.
At discharge levels this high the cell interconnects, cell cooling, etc., are all critical and would vary for each application/customer. Testing like this is left to the customers since there is no real need for the manufacturers to do it. Believe me, if they had extreme discharge test data that looked good it would be in the presentations or application notes for the cell. :slightly_smiling_face:
I should ask though…what is ā€œextremeā€ for you? Beyond datasheet ratings I’m guessing?
