I usually have the probe wires running over my hand, so can feel when they start to heat up it’s time for a beer break
How do you plan on charging this guy?
Single use pack
My biggest fear
That’s gotta hurt
It’s probably a charge and discharge thru the same port bms.
I thought that might be the case too, hope so!
It’s a same port charge/discharge BMS from dickyho.
This is a noob friendly board that I can borrow to friends.
For slow welding, maybe a battery or two per year, a lipo will be sufficient
If you want to weld for longer periods of time, a little faster then you will need capacitors because lipos will overheat and blow
12P * 15A=180A // 12P * 20A=240A
12P * 3Ah=36Ah
8P * 35A=280A
8P * 4Ah=32Ah
40T testing determined it was more of a 25A cell or 30 if temps are controlled. So that brings it to 200A continuous on the pack with 1382Wh versus 1,555Wh on the 12s12p
Yes, those are the specs on paper
All this means nothing in real world situations. I’m really curious how it will go. I will update you in a few weeks, when we finish the 2nd prototype.
To be fair, just about everyone else is happy with lipos.
If you’re building for yourself and can take your time, lipos are great. If you’re building as a service, have done it a bunch of times so you’re fast, it’s not hard to push it and blow up the lipos.
@Acido did you get the capacitors? Much better?
Bench testing correlates to real world testing?
What is the information you seek?
I’m looking more for acceleration, top speed, range and max A.
I’m sure most people here would go with the 30q because it will have more range. With a battery that size the difference in acceleration will be negligible since I don’t think you will even come close to pulling that many battery amps. @Chricious
Oh, I have already the 30Q and I maxed out 114A battery and 160A motor current in 80A setting. Next test will be at 90A and if the temperature is fine, we will try 100A each. I think at that point their will be a difference, but not sure in which direction though. Range should be in both setups more than enough, but I’m curious to test it anyway.
