The battery builders club
No worries bruh.
I personally like to throw a cutoff wheel on my Dremel and hold a shallow angle to the cell ends, use the outside edge of the wheel and grind away.
I thought of that, but I didnt want to cut through the cell housing. How thick is the cell housing anyways?
@Battery_Mooch :point_up_2::point_up_2::point_up_2::point_up_2:
I couldnt say but it’s something I’m weary of. When I say shallow angle, I’m talking 15°-0°. Its a fine line but it works for me lol.
Kids don’t try this @ home
Cutoff wheel is excessive and imo not the right tool. Flush cutters and a circular grinder on a rotary tool. Be thorough with the former and sparing w the latter.
You gotta be super careful with the cutoff wheel, but it definitely makes short work of it.
I also use the stone ones
Thin.
Be very careful and go very slowly. If you hear a hiss or “sizzle” sound of gas escaping, you went too far and that cell is now trash. If you smell a sharp chemical smell, same thing.
It’s better to remove too little material and have a slightly harder time welding the new nickel strips, than to remove too much nickel and ruin a cell.
That sounds like a reasonable assumption, yes
Thx, slow and careful it is.
Will a 60A BMS be okay with my flipsky 6354s? They are rated for 65 but the website suggests a 50A BMS
Use the bms for charging only, and bypass it for discharge. The VESC will handle the low voltage cutoff.
A 20A BMS should be fine then.
Is 20A a requirement or can it be lower i.e. 15A?
That number generally refers to discharge, but it’s linked to max charge rate. You can go lower, just make sure your charge rate is below the maximum.
The output amperage doesn’t really matter if you’re wiring for bypass. Just be cognizant of the charging current the bms is rated for.
I’ve found my carbide burrs work well too
I use a small flap wheel. It’s just the right amount of being aggressive to be quick, but not dangerous.
Any thoughts on using 3m vhb as pgroup isolation?
sounds expensive
That shit is crazy good adhesive, no idea how well it would stand up to abrasion but because it sticks so well i doubt it would have the chance to abrade. I don’t really see an issue with it
Yeah I agree - I doubt the cells could move at all
But it’s so expensive
