sliced into it. ground off a corner. no sparks.
1h of salt water:
no signs of trouble. will leave it over night.
but seems legit.
1h of salt water:
but seems legit.
You must have a lucky tracking number. I have
over 2 kilos is still stuck in package purgatory
came DHL
lmk if you need some ahead of time.
Did your time for refund lapse yet? Mine does in 2 days still waiting
they extended it.
I hope it comes soon
That is legit bro
bruv.
you covered the foxes
(nice work )
that’s an interesting form/config for a 12s–what’s the board it’s going in?
Better? The series wires are not playing nice with the paper, maybe I’ll put some foam core in next time
Seriously looks awesome, but what board is that going in? It’s such a weird form factor
It’s for the integrated board, 12s2p P42A with 30mm * 0.2mm parallel connections and double 14awg bound silicone wire series connections
Wow lol so much room for activities in there
Right? Why not go bigger on the battery? Cuzza compartments?
Yeah I have oodles of space in there, due to the covers the phase wire ports will have the Unity sits basically flush with the inside of the pocket and the BMS is a perfect fit in the corner so I have an absolute ton of space to get a power step down module and a LED driver in there…rainbow ultra dense addressable LED strips down each side so its gonna be purdy in the dark. Since its the drop in METR module and the VX1 receiver is tiny I will not have many dongle wires running around, just the LED stuff and the power/charge lines which will be on the outside
Could add a qi charger?
I don’t need it…I want this to be my common driver so adding more cells would make it too heavy, it’s only running dual 6355 motors with urethane wheels and Delaware is a fucking pancake of a state so it’s not like I need the current draw
If I want more range I will have the Black Bear board with the extended range pack…I mean I guess I could run it on this too since its all 12s
I don’t understand
I’m seeing all that space inside a wooden item. First thing I’d do is fabricate a integrated Qi charger. Could charge phones and possibly the remote.
Woodworker/electronic nerd in me wanted to speak
Oh yeah that would be pretty easy, I have the 5V step down there anyways so I can dump 15A into the charger lol
I was going to have a USB adapter in there for wired charging but wireless wouldn’t be a bad plan
