VX2 throttle spring must’ve broke or something, but it suddenly started sticking in the full throttle position. Brake doesn’t stick.
Literally almost died on a main road - thank god I’m just left with an arm full of road rash.
Don’t ever buy the VX2 or flipsky remotes, just ball out on a good remote promise you won’t regret it.
Mine did the same thing approaching a stop sign. Took it apart and wiggled some shit been fine ever since. The cruise control is the worst about that remote. Mechanically stuck ok I can deal with it, electronically stuck I’m more confused than a dog with 2 peckers.
I had passed a stop sign and got onto a main road, went full throttle and when I let off it stuck, I had adjusted my weight back when I let off and as it kept pulling I wasn’t ready for that extra push from the back and it flew beneath my feet, straight into a curb and narrowly missed a car.
This board pulls harder as it gains speed, and when I let off is about when the board pulls the hardest (around 15ish mph). Although the evo is great for bracing for lots of power from the back wheels (easy to put your foot against the double drop) I just couldn’t handle that unexpected power. Thank god no cars hit me or my board, as my lipos could’ve caught fire if ran over.
Seems one of the little plastic things on the throttle wheel broke. Brake side has two and doesn’t stick, throttle side only has one and appears to be missing one.
Where I circled in red did one of the little plastic tabs break, or are there only one on this side and two on the other (white circle side) ? I couldn’t find a broken plastic piece in my remote…
For fun I tried to pull the brake lever past its stopping point to see if I could break something but couldn’t and I don’t push my throttle up that hard so idk.
