Absolutely.
Agreed. Though the spot welds in the custom pack have a MUCH higher resistance than the huge laser welds in the other pack. IIRC that the other pack had laser welds.
Moliās are great cells, durable as heck too.
Absolutely.
The 1p Eve40pl custom battery performing nearly equally to the Forge 2p JP40 in that specific tool, makes me think the copper nickel sandwich in the custom, and wiring to from BMS to output terminals is perhaps lesser overall resistance than the factory Milwaukee.
But maybe that Milwaukee forge 8.0 battery has a hundred + cycles and 14 months of age on it, making the comparison unfair.
Torque Test channel has a new video out, Centering on Tabless cell power tool battery packs.
Interesting disassembly of some of them too, especially the Bosch.
The Bosch pack that was disassembled is not the 18V+ tabless-cell pack, itās just the standard 18V pack, so the performance was understandably lacking. They pinned a comment regarding this IIRC.
I thought the performance difference was interesting, as perhaps a 40t cell pack vs P42a, or older and newer P42a.
I watched on a smart tv, did not yet see comments.
Interesting that Dewalt and Ridgid are using JP40ās too in their newest packs.
Those bosch series strips looked pretty thin.
Fwiw same factory as milfuckee
TTI right? They make Ryobi too, i think.
I left a pair of Makita drill and driver in California when I moved. Their batteries were shot, and I didnāt have the room in my overloaded rig anyway. Went with Ridgid for the ālifetime service agreementā, when I replaced them. Brushed versions though. 2.0ah standard batteries. Got a good deal on a Ridgid angle grinder and 2 4.0 ah batteries. Home despot has pretty good deals on Ridgid batteries occasionally.
I like Ridgid, as they have the low voltage disconnect in the battery, not the tool, like Dewalt and Makita, donāt know about mikwaukee. I used them to power a booster to charge my eskate battery a few times.
I donāt require Tabless cell performance in my cordless tools, but next battery I build is likely to use them.
I have been doing a lot of reading on tabless cells and am a little spun. Between the Ampace JP40 and the EVE 40PL whatās the general consensus on which is better for a high amperage output pack? Id be looking to build a 12S7P of it with the goal of providing 400A output.
I can find them for within $30 of each other shipped so pricing isnāt a big difference or concern
From the tests Iāve seen, the jp40 out performed the eve 40pl
JP40 is supposed to have slightly more discharge, 40PL is supposed to have better consistency between cells. Mooch has write-ups on both
Also worth noting that the worse consistency might come from the rumour that the JP40ās available today could potentially be a lower grade cell. So this could change at any point.
But for now Iād personally give up the very small performance difference and go for the EVE for itās consistency.
Im leaning toward the EVE also. Thereās no world in which Iāll need 160A burst that the JP40 can do.
I wonder if I ever even have pulled 400A total from a pack.
EVE at 70A in a 7p would give me 490A available in burst, plenty for a hobby wing max4 ESC setup.
That 160A/2sec spec isnāt for the JP40. Itās for the AM04 and thereās no life cycle testing to judge its impact on the cell.
Ampace rated the JP40 at āonlyā 140A/5sec. ![]()
Longer bursts at 60A (if not hot) and continuous at 45A.
I definitely prefer the 40PL right now for its consistency and we may not be giving up much in the way of performance eitherā¦more testing to come when a pile of 40PLās arrive.
Thank you for the clarification
Isnāt the āburstā rating essentially irrelevant as the times are all different and we donāt know how long our longest āpulseā might be?
I was under the impression since the vaping days that CDR was the only amp rating worth caring about.
Consider it a burst ācapabilityā, one that many cells can do. IMO to make it a rating we need to know how often frequently we can do it and its effect on cycle life.
For many applications, yes. But moderate bursts, 5sec perhaps, can be handy for PEV pack acceleration considerations. Different lengths can be applied to different applications that we might not be considering.
But, yea, most of these capabilities are listed merely for marketing purposes IMO.
For comparing cells, pretty much so. Unless you get equal true burst/pulse ratings you can directly compare.
In my tests, all samples of the JP40/LT significantly outperformed the EVE 40PL.
Just released a deep dive video about the Samsung 50S, where I discuss its performance compared to the Ampace in the case of a high draw pack with a small # of parallel groups.
Also: as empirical evidence, Iām the guinea pig for real-life use of these as Iāve gotten 200 of the JP40 (LT labelled) an am building my next Surron pack with them. Will see how they perform over time.
The IR of all cells I got was very consistent. But the voltage did vary by.07v between the 200, with two outliers with .20v difference. All Samsung cells Iāve ever gotten have been within.01v or less. So this MAY indicate more difference in self discharge. Weāll see how they do.
But for my personal use, after seeing how the Ampace trounced the 40PL, I had ZERO desire to ever buy the EVE.
And to add, Iām not just talking about bursts of 140A. Iām talking about better performance (less voltage drop and temp increase) across the board at 30A, 40A, 50A, 60A. See the results of my testing.
In all my tests, the JP40 significantly outperformed the EVE 40PL.
I bought 200 of the Ampace (LT labelled) for my next Surron pack.
If youāre looking for more of a āname brandā, then go with the EVE. If you want the best performance and are willing to take the risk on an unproven over time brand, the choice is clear.
