So I’m in the process of parting together my first DIY eskate, and am looking to get some advice.
Currently, my only eskate experience is on a Boosted board, so the scope of my riding knowledge is quite small.
I’ve heard great things about both, so I am having trouble deciding if I want to make a more conventional street build, or a street carver/mtb style build.
I plan to ride almost completely street, with maybe a few packed dirt roads sprinkled in.
Here’s the stuff I’ve decided on:
4wd 6396 Motors (bioboards maytech ones)
Stormcores
3DS Helical Gear Drives
3DS Hubs
Around a 12s8p 21700 Molicel p42a pack
Top speed in the range of 40-50 mph or ~64-80 km/h
Davega + Metr
Hoyt Puck
Here are my 2 options for the rest of the major parts:
Option 1 - Street Build
Redember 44
Eboosted Enclosure
3DS FB 275mm Hangers
3DS Adjustable Baseplates
~6.5in Tires (trampa urban treads?)
Option 2 - Street Carver
Hearo Bro or Prototipo Deck
Some sort of undermount enclosure
3DS FB 320mm hangers
Matrix 2 Metal Baseplates
200x50 Kenda Tires
I’m also open to suggestions
As for what I think, eMtb or carver boards can look a bit wonky with the super wide trucks, but I’ve heard they are nice to ride. Also, I wouldn’t mind clearance for larger tires.
You don’t need 6396’s in a 4wd setup, go for 74’s instead or 55 front and 74 rear.
Gearing for 80kph top speed is straight up retarded, especially after only coming from a boosted. Gear for 60kph top so you can comfortably cruise at 50kph.
Get MBS hubs instead of the trampa ones, they assemble and come apart much easier should you ever need to change a tire or inner tube.
Instead of the prototypo you could get a flux deck instead, it’s designed for 12s9p 21700 in 2wd so you might have to sacrifice a p-group. Kaly also makes very nice decks, and because of the wings they offer a lot of grip.
The channel trucks get you so much more involved with the ride. I have 200% more fun on both my mtbs, even just for on road riding.
Haero deck and matrix trucks is a great setup. Don’t listen to this @J0ker above me
What are your range requirements and condition of streets? That’s the only other factors that would make me choose the street build. If you use fivestar hubs, you can use tires from 6" (maybe even 5.5") through 10". Plus they’re cheap and light and take dye very well.
That’s a huge upgrade from a boosted.
That’s like having a ford tempo that runs off two cylinders and replacing it with a McLaren.
Definitely a powerful plan.
Personally I’m not crazy about the feel of four-wheel drive on traditional skateboards.
Mtb/carvers with wide trucks and the deck shape seem to support 4wd without sacrificing steering or clearance issues, especially with big motors AND geardrives.
That top speed is a bit much unless you have some serious downhill experience going that fast on a piece of wood.
This makes me very nervous. Your deck and enclosure should be the first think you decide on when planning a build.
(Actually no, the second thing. The first thing should be safety equipment matched to how you plan to use the board. 40MPH is a lot, especially coming from a boosted. Dont mess around about your safety gear.)
But you should always figure out your deck and enclosure combo first so that you know exactly what you can fit. Especially if you want to fit a 12s8p 21700 battery. Thats going to cut your options down a lot.
The prototipo deck and enclosure can just barely fit a 12s5p 21700 with a unity and a daly BMS and 0 room to spare. Ask me how I know That deck and enclosure is also unobtainium right now as far as I know.
The Haero Bro rides really low. @BigBen makes an underslung enclosure that can fit a 12s4p 21700, but I dont know of anyone who makes an enclosure for it that would fit 12s8p and 4 ESC’s. You would potentially have clearance issues with that much battery under the deck.
Def get the flux deck/enclosure. I’m fitting a 12s9p 21700 cells into it soon and that only takes up 3 of the four compartments in the enclosure. You can easily do 12s12p 2170 if you top mount ESCs.
Also, Matrix 2s are fucking awesome. Idc what anyone says about that
If you’re doing that big of a pack and 4wd, you’ll have a HEAVY ass board. I personally haven’t tried 4wd yet so idk if it’s worth it, but I get enough power with 2wd and some 6380s
