Hey Guys,
So I got my setup up and running, all was sweet. But - when running on cracky roads and pavements I noticed a strange coughing clicking noises coming from the board, I couldn’t recognize the source. So I took everything apart to try and find the root cause.
It all came to the motors eventually. But when saying motors - it means when they are even not connected, i.e. a strange echo from the cans or so, not sure what’s causing this.
These are Maytech 5065 motors, no loose magnets or anything inside , I tried 5 different motors. All are maytechs 5065, all gave the same results. Everything except the noises is working fine and the motors are fine. Also, everything is tight and in it’s place.
Running with just the motor mounts without motors makes no strange noise.
I have other boards with street wheels as well and do not have this issue.
This is how my test looks like.
Link to a video recording: Clicking annoying noises
Then pushing manually over cracky roads or pavements.
It’s not a deal breaker on this build, however, it drives me crazy.
Anyone got an idea what can cause this ?
UPDATE:
Found the root cause: the motor cans.
Doing this with isolation electric tape on the cans and taking out the belts, pushing manually, everything is silent as hell, without the tape, pushing manually (without any electricity), makes this ugly noise.
Now that being said, any ****reaking idea of how to solve this crap? These are brand new Maytechs and they are working just fine, I tested 5 different motors, all suffer from the same phenomenon.
Solved finally - really stressed my OCD here …
@rich you were right in your senses ! Eventually there was a tiny space between the can and the baseplate of the motor, putting a shim between the pulley and the mount, made the can stick into the baseplate preventing these tiny movements which lead to silent smooth drive
Thanks.
