Stooge Raceboards Web-Store Up
Just added wheel widening kit for the Summate Metro style wheel.
Gah! Just got a bunch of 3D printed ones. Oh we! GLWS!
Edit: just noticed these spaces don’t offset so you’d need much longer axles.
I know the sunmates and metros are clones so safe to say they fit the trampa as well?
Dude you have the best timing. i was just going to buy a set off metroboard since they just got them back in stock…
Does anyone know is those wheel hubs are the same bolt pattern as superstars?
2" bearing to bearing width.
Our axel spindle area on the 3-link has 2.5" of space. On the geared side with the spur carrier bearing added it still requires a spacer added to make the gap. We pull a ton of turn G. Glad to have the bearing pocket out under the rim lip. Takes some of the side load fulcrum off the bearing.
Looks like these are 68mm.
@bboybowzer safe to say :+1:
The site and products look great! Answered my pending questions about bushing colors/duro, and “How much if I want to upgrade to 4wd?” too. :+1:t3:
Are you going to start selling tires too? Or if not, got any links to your preferred tire options for those wide wheels?
Thanks @MoeStooge I’ve been waiting for this :call_me_hand:
Metroboard 155x50 they also sell pulleys.
3-link DH with Max Capps.
Podium in our first Competition. 50+ mph on Dump rd yesterday.
78t Mod1.5 open HC steel gear drives are in. Should have these up on the web-store by end of the week.
67t are currently in transit and will be available a few weeks later.
Will have 11t and 22t 8mm pinions available as well.
Spurs will come with a carrier bearing that fits 10mm axel.
Universal pattern that will fit most 5 bolt wheels.
Is there a single truck option? Its the entire reason I went with apex air over you and I still want a single 3 link with motor mounts later. Ill buy 2 if I REALLY gotta but I plan to mix and match so I dont NEED two.
I have no problem doing a single. Shoot me a PM on this.
I will when im on my next buy phase. Already got an air this time. Air in the front 3 link in the back sounds like fun.
Air is built for 0 degree already tho and 3 link gives more lean which you want up front…
Not a terrible idea to want extreme precision on the back though.
See the way im imagining it is on a deck with angled tips. Nice floaty pkp action in the front, but the 3 links in the back I imagine would work well to maintain the balance of stability while allowing my back wheels to follow my front wheels in a smooth steady fashion.
78t spurs 11t,22t pinions are up.
67t spurs are a couple of weeks out.
“Spur Gear – stooge raceboards” Spur Gear – stooge raceboards
