67t open spurs will be up on the web-store in a few Days.
22 &11t x 8mm pinions are available as well.
sellin stooge gear.
Love it.
Any ETA for the new wheels being available for purchase?
Hope is to have these available in 6weeks.
What do you recommend for currently available tire options for your widened hubs?
Sunmate 150x50 was the best option we tested.
Metroboard 155x50 should be available 6-9months according to Metroboard.
Added to web-store
Links to the 3-Link parts.
Available on the web-store
SRB V-5 Racing Chassis
Chromoly tube chassis, Deck and Pan are .063 Aluminum, SRB 3-link steering assembly on Riptide bushings with choice of Long or Short 4130 motor plates , custom GT2B controller case, battery trays, vinyl wrap.
SRB 3-link can adjust to run indoor short tracks or outdoor long tracks
Install your motors, esc, battery, radio, wheels
SRB 3-Link 14.5" hanger (tip to tip)
spindle takes 10mm bearing, spindle length 68mm
Premium SRB bushings by Riptide Sports
Long Motor Plates will take 94mm long motors, small bolt pattern, 8 or 10mm shaft
Belt Drive OK,
Adjust: Wheel Base, Tilt/Steer Ratio, Track, Bushing Preload, Motor Plate Clocking.
SRB “HD” 15.5" (394mm) 3link Hanger. Heavy riders, severe Duty. 5/8"(15.8mm) Carbon Steel axle. Larger Radius Rod and Motor Plate mounting. Accepts 100+mm motors (214mm motor plate spread). Spindle options of 10mm or 12mm bearings on 68mm spindle length.
For all the Big Boned Ballers. Coming Soon!
Calling little @poastoast big boned is a bit insulting, but this is great news! ![]()
if i have moni you know i’m copping!
gotta use that raptor deck one way or another
SRB “HD” axel support is here.
212mm motor plate spread.
15.5" (394mm) tip to tip
5/8" (15.8mm) carbon steel hanger
10mm x 3.5" (88.9mm) spindle area
HD truck sets, HD Track Pack
Replacement: HD axle, HD Motor plates, HD rod mounts, on the web-store
Riptide Krank 93,96a available.
Also, HD 44mm motor plates and HD baseplate brackets will be available late next week. Race wheels back in stock early June with 45a, 50a and 70a options.
Stop by and see us at the Electrify Expo in Longbeach June 3,4,5.
#017
What’s the duro of the race tires I’ve got? 45a?
@DEEIF yours are 45 rear 50 front
