Learned today that the Xlx are discontinued after the release of the xlx2. Thatβs kind of sad as they were working pretty good and the xlx2 is a considerable lager form factor.
Edit: nah not much bigger. Just the height I would have liked not being so high
I have only seen that esc (the old one) ran with the matching castle 800kv motors on 5th scale r/c. and i thought they were slow p.o.s.
thats soo crazy to see these pushing an eskate so hard!
@Gilbert Xlx2 is a good esc with a bug that still needs addressed. There is an undesirable βdrag brakeβ effect when re engaging throttle after coasting in neutral. Castle has been informed on this and assures me their engineering dept has been notified. @fessyfoo raced this esc at Apple Valley and can elaborate on his experience with it.
As to date we still have ZERO esc failures using the Castle Xlx and Xlx2.
Torch bro. Iβm not kidding btw, dead serious. Small pencil torch is enough for βsmallerβ stuff like 6awg, you should watch videos of guys rewinding large induction motors, fifty-to-a-few-hundred HP ones as large as a person. They break out the oxy torch and large cutting heads to heat the wire bundles.
Itβs really a lot better though, once you get to the point youβve got to be on the wire any significant amount of time with an iron, itβs actually very inefficient and not optimal for the conductor, as the copper is sucking heat out of the end almost as fast as you put it in. Appropriately sized torch and proper cone adjustment and you can solder larger wires as fast as small ones using the iron. Just takes a little practice.
I noticed and adapted pretty easily to the drag brake. it wasnβt much braking. In racing Iβm trying to be throttle on or brakes on anyhow, and I drive my EV cars in regen/drag brake mode as well, soβ¦ it wasnβt too annoying. I should say it wasnβt annoying at all.
With cars and go karts you can dial your driving by either having higher entry speed, higher mid speed or higher exit speed in corners, and higher mid speed for example will call for some balance of your car weight & acceleration and minimal braking instead of hammering it (you then also need to get sometimes light on acceleration to be able to apply minimal braking)
