Instead of “Battery Max” at 84A and “Motor Max” at 55.29A, try switching those around. Put “Battery Max” at 45A and “Motor Max” at 90A. That’s probably going to solve your problem.
He already had them setup to 95A before. It’s not this. @Tailele i think the kv of the motor is a bit too high. Are you able to reach top speed in any circumstance?
Also, again, i would like to see the next tab down to understand a bit better what is going on.
It looks like this
Sorry, there isn t…in any case i change the parameters, 85 Amps motor and 40 battery, the situation Is the same. I think that Is the vesc, probably works for skate and so the torque in the First step Is more delicate.
I would repair the Two flipsky…i think that the arm Is fault un both and in One a micro too…
If your MCU is >150°C then your hardware is trashed and needs repair. There is absolutely no normal operating circumstances where the MCU has those kind of temperatures.
It depends on the component.
In your case, that large hot component is where the firmware lives, so yes, you will definitely have to program the replacement.
