1. With auminum case and spare place to add cooling fan. 2. Still use FDBL0150N80 Fet 3. Add 3.3v/5v/12v Circuit with auto-recovery fuse for better protection 4. Keep 12v power supply port 5. Add IMU(bmi 160) for Balanced Board’s Convinience
**6. With anti-spark circuit ** 7. Logic and Power stage are seperately available as spare parts 8. Size(without fan): 85x54x25mm 9. Handle 16s safely, Continous current 100A 10.Keep all necessary port: PPM,UART(adc1/adc2),Canbus,Hall sensor,TypeC usb and a hidden SWD port.
Time line: Beta test version is available in END of June or Early July at 150USD for top 50pcs
Final retail MSRP is not finalized yet.
I would say its “probably” fine. If its in an enclosure there would be clamping force making sure that it doesn’t shake loose. Not entirely sure if the vibrations would be enough to cause short or medium term damage to the connections as long as the enclosure keeps the components relatively stable/secure.
