thanks, big help!
yes, please try to remove other UART connection, then re-scan it . thanks! if you have remote , please use remote to turn on canbus in first priority
you’re welcome.
I’m so satisfied that I ordered 9 more Ubox (Clément PULIGNY)
Which port on the UBOX is this referring to?
The middle bottom port. It says horn and light on it
WTF! You have 10 Esk8 boards ?
or Fanboy ?
Is that a problem?
French Group Buy
Fuck, didn’t know there was a group buy running, I just ordered one. What price/unit did you get ?
Not on the forum, it was on a french facebook group
as i understand the onboard reciver takes 1 of the uart and the bluetooth take the 2 uart now u dont have more uarts if u want to free up a uart for metr ex u need to loos the blue tooth or the remote right
are u using the reciver to the wand u can buy at trampa or the build in bt reciver in the ubox ?
Am I silly or does traction control not work. given it is under the PWM tab in vtool I am just generally confused.
i dont see what peak battery and motor current the single version does…what will it do? It’s running the firmware that will allow it to do 300a but can do much less safely? it says can do 100 amps continuous.
I think i remember someone saying it cant do push to start right?
I bought it anyway.
The remote also works in PPM mode, you just lose telemetry to the display.
Can some one clarify how to get stop light work on Ubox, a video would be great.
Plug red (12v +ve) wire of light into Pin 3 of horn/light port on ubox. Plug (GND/black -ve wire of light into Pin 4 of horn/light port on ubox. You should have some single ended jst wires that came with the ubox. Remove the necessary wires from the JST pin header so that you just have the two wires in spots 3,4 and you can solder the other ends to your light.
It should work. Make sure it’s set in the master side, or just set it on both sides to be sure.
Single Ubox Does it run Original Firmware or costum 3.3v or 3.44v to mcc ???
