Good call - I saved it on WayBack Machine as another way to archive it.
I’m interested in this very much as well. If you have different batteries, such as 13s and 16s, seeing how the performance differs between such voltages.
@Lee_Wright are you also getting one of their BMS’s? From what I’m reading it wont work with any BMS other than theirs, which is still in production? How are people intending to run this thing?
edit:
I see it’s only the readouts that require their BMS, sorry i was just confused there!
just got 2x 8s8p I’ll be running at 16S with this on the bike,
@hardunclejohn it’s not possible to parallel the 2 sides on this correct?
Wait, what?!
the bms readout on the remote and connection on the ubox is just for their bms, otherwise it works
Thanks @Scepterr yeah I was confused about this, makes sense nowm thanks!
Any idea when the BMS will be ready for ubox ?
How many phase amps per channel can it be set?
How long did delivery take with 4px for you guys?
LoL but so easy to fix, just push it back on there
yeah haha but a real fix being some superglue?
real fix is solder the wire directly on the pins
I can’t tell you how many times I’ve soldered wires onto JST pins.
For when you absolutely don’t want it to come unplugged. Ever.
Lol! Love this. So far this things seems to function like a good old vesc. Did motor detection with it at 10s, remote paired to it pretty easily and got motors to spin. Next gotta finish that 14s pack. The remote still needs to be paid to it btw. So gotta charge app setting to UARR, put remote in pairing mode and then power cycle the vesc
I’m hoping it magically makes the onewheel hub work
@John-Spintend are you working on a bms that will be compatible with this vesc? How exactly does that work, or is there a bms currently available that will pair with the vesc, so I can make use of this remote function to check your pgroups
I think so far there is no other bms working with it, but they are working on a bms.
So I try to set the mainboard for my scooter. But i have Two problems very doungerous for my safe…sure i wrong somewhere but i don t understand what…
The First problem is that with a cable throttle, when i push It, sometimes the signal remains up and so the scooter goes away without stop It even if the throttle Is down…
The second problem is that the regeneration brake don t work.
As i said , sure i wrong a set up. What type of set up must i set for ppm…i choose “current no reverse brake ventre”. Is It correct?
I need picture showing your set up to understand and screenshots of the setting. I replied to your pm
