It works now! Pulled the triggered on 1 Ubox with remote. I will probably open the remote just to get the pcb and so be able to use the features linked to it on my escooter.
Would be possible to command the throttle by ADC while keeping the remote function such as light, can bus switch ecc? For instance by activating the UART connection on the slave side to command the features and master side of the vesc for throttle with ADC.
It’s going with 14s 110A battery (total) so please make your best unit!
Looking forward.
Thank you!
Also shouldn’t your voltage be reading a bit higher than 52.3 V if you’re running 16s?
In terms of voltage, this is the voltage drop on the battery and the battery circuit. After all, the current is tens of amperes.And it’s not the professional power supply. If you have interest to see the up to more voltage display, I will post a short video in ins(@spintendpower) later.
Hi,Friends, there is some update for our Ubox antispark switch, I decide to remove antispark function ,replace It by Amass
Antispark function XT90S connector. It’s not because current design problem but because some user may not trust it and it’s my first product that I don’t want to run any risk on it. It’s already update in our website. Www.spintend.com
If more people still want the Ubox keep antispark function , we can also change it back.
And so the shipment after Sep/15th is changed one without antispark, the switch function is still there.
The horn and light and can bus are integrated controlled by the receiver. Only if you still use receiver to control them, you can at the same time use ADC throttling.
