Will be interesting to see how reliable the antispark is in this ESC. Maybe @hardunclejohn could comment if it’s the standard mosfet kind, or similar to the new reliable kind used by Flipsky, 3dservisas, Lacroix, and such.
paging @Gamer43 for antispark related stuff
I’d have to see the inside to give it a thumbs up or thumbs down.
Surprised you didn’t ask them for the firmware forkfor this
Not sure if it’s visible in these photos OLD QUESTION: What is the best VESC on the market that is available to purchase?
I am not seeing an antispark circuit, but the PCBs are double stacked, so there are some things I can’t see.
so there’s a possibility he implemented a sleep mode in the firmware, which would get a thumbs up.
If not, then we’d have to ask the dev if he implemented high side switching with inrush current management.
it’s possible someone named quinn foster has purchased one of these.
possible
it’s ok you do not have to make a build specifically for testing. I will use it for an higher voltage application, in esk8 so current will be a bit higher but should be manage without problems.
I plan on using it to test out the onewheel hub but since this is a dual I will have to find a new home for it once I source a single VESC.
I ordered one for science and we will compare it with other VESCs.
I’ll take this burden off your hands free of charge ![]()
ok but I need you to fly all the way here and help me finish the rebuild.
I’ll pay you $7 an hour but I expect speedbuilding.
At 7$, you aren’t even paying for me to get out of my house😂
Level with my salary and then we’ll talk
ohh canandollars right.
$10 an hour
Ftfy
(And that’s on the least of my 3 salaries)
will consider use typeC in our next model
Thank you for your mail . Will solve shipping problem in web. Please try again.
It can’t support other BMS ,we’re speeding up to design the hv BMS.
I did learn more lesson from market anti spark switch : usually, sparks are caused by current inrush to aluminum capicitors. So,Ubox places mosfets between ground and the negative poles of aluminum capicitors. When battery pluged in, mosfets are not switched on immediately, capicitors are slowly charged through a resistor,untill user push power botton to power on ubox, these mosfets will then switch on.
There is many problem in antisprk switch design in market, we did learn lesson from them. Hope to see more market feedback on Ubox, and the best way is to remove anti spark switch circuit by replacing antispark Amass XT90S connector. If there is more agree on it, I will consider to do it in next batch production.
Poll on it! Thanks
