Im very new to Esk8ing. What do you mean by it dies over 14s?
he’s saying 190KV motors aren’t rated for 14S; you’re running 8s, you’ll be fine
this esc is meant for 16S. Perfect you can start on 2x 8S parallel then switch to 16S when you get the right motors.
what would i have to change about the motors?
more or Less kv
different sizes
and how would i go about charging it.
High voltage and High amperage motors?
More inefficient in motor w higher voltage
(US) WTS 2 maytechs/LHB 6374 90KV motors $255
LACROIX Stormcore ESC and iOS app info
^this one is fun
damn my fickle heart is brroken
has anyone tried blowing up some meepo hubs or the like?
I am planning on whipping up an AWD Ebike, as those are the only motors I have now that would survive.
With a BMS and a charger
This is probably a stupid question but would i be able to charge the 16s battery with my 8s charger? like charge one at a time.
If this guy is pretty new to Esk8 it probably isn’t the best place to start looking at 16s batteries etc. That’s unnecessary for 90% of experienced people!
It’s technically possible but comes with such a large fire risk that it’s not recommended
A BMS and a charger are cheap.
There isn’t anything wrong with 8S though, it will work just fine. Using this ESC is kind-of like buying a Lamborghini for a 15mph (24km/h) stroll though.
Exactly, and there is nothing wrong with that, @Neenong you just have larger safety margins than required. Which is great!
but it was so cheap even if i use it on 8s
Use it! It will work awesome.
Exactly, you made a good choice. Nothing to worry about, you just have potential room to expand in the future
true true
6-8-10s to 16s is the new 10S to 12S jump apparently
