Of course I do bud. You guys want to fuck cartoons
Sorry bud.
Sniper edit haha I don’t watch henti but I do get it
My first crush was Faye Valentine
Aka my first real boner
Little mermaid here
don’t be scared to snip off each corner/ or grind the pcb of the BMS, If there isn’t copper tracing, your good to go.
You can also cut off the bottom most 3-5mm of most all bms , and solder leads directly to the Resistors on the bms if you really need to squeeze in. Then you can add a small pigtail *to keep you from accidentally shorting if you’re not so good at soldering. Let me know. i’ll do for a 6 pack of IPA for you if you need
hmm not so sure id like to do that to my Neptune, plus I ended up having enough room.
I zoomed in… Yes… I wouldn’t fuck with that either.
That isn’t cheap… are you a gadget guy, or really like cell by cell stats… I’ve had my eye on one for a short while.
I like having the features if I need them.
In the realm of things it’s a small price compared to all the other parts.
I haven’t installed a bms on my other board and it’s going on a year of weekly use.
Yay!! Definitely not a lot of room to spear! Can’t wait for you to finish her up and share some thoughts on hypertrucks/proto combo.
you miiiiiight need to run a hard rubber spacer between deck and enclosure to get the motor wires in there cleanly.
Ehhhh there’s plenty of room hahaha
sounds like girls in my grade
Woah!! Thts a tight fit!!
That’s what she said!!!
This is so freaking sweet dude. One of the coolest decks I have ever seen.
Thanks man
It’s really something special
