(Soon)
Parts list ordered so far
Flux Motion Deck+Enclosure
LacroixHypertrucks+6389 Motors (Might order the falcon drive)
12S8P Molicel P42A
There have been some issues with that, recently brought up. There was a longer post as well but I can’t find it.
You could look into this instead if you’re in the UK:
https://www.electricskateboarding.co.uk/batteries/12s8p-24000mah-trampa-monsterbox-pack
Summary
I have a spot welder at home so I do/can make my own packs. But I wanted to go the cell fusion way this time… Do you know when the problems where ?
TL;DR: Trampa are trying to produce safe replacement parts to fix existing packs / make new ones safe. So when = currently.
So I would suggest you build your own pack since you know how already.
Just buy a battery from Apex, they are the best in the UK at the moment when it comes to batteries.
Summary
Can build my own but thanks for the advice !
That’s great! Make sure to read our battery building thread! Make sure to post progress pics too. Always good to have an extra set of eyes on a battery build.
Summary
Any europian vendors for 6384/63100 motors ? getting a bit sick of paying inport taxes ?
Summary
So I ordered some Reacher Tech V5.0 205 KV motors i hope that they are less screamy over the flipsky battle hardened ones.
Summary
I am thinking about going 16S but not sure if the difference would be really with it ?
No reason to bother, unless your ESC is thermally bottlenecking you.
Why take a 205kv ? It seems super high for a mtb, especially on 16s
Trying to break the 100 kph ?
Did you get this deck? And if so when you get the trucks and wheels on can you do a jump flex test ![]()
I’m curious to see the flex
Thanks
Summary
I actualy neve tought of that… Thats the kv type I always kind of get with my road boards. And my current board had 190KV and that does not go faster that 60kph. But im going to check if i can still adment my order…
Summary
Managed to change the motors to 138kv. Will fit my needs way better ! Thanks for the heads up ![]()
Could an admin close this tread.
Only sales threads get closed
Ah oke
