4WD Semi-Complete Build
Description
Hello all,
I’ve been out of the esk8 loop for a long time. I built this machine a few years ago, but really didn’t get to ride it much. I spent a lot of time building and tweaking things on it, did quite a few test rides at the park, then I got a dog who needed to be walked a lot. The kind that would get you killed if you tried to walk him on an esk8. The board has been on the shelf for about 3 years.
I’d like to sell it here as a semi-complete to someone who wants to put their own spin on it or parts harvest it. It doesn’t come with a battery, but everything else is there. It comes with all of the below components plus some extra belts, risers, Viscous Grip Tape, and some Metroboard pulleys that I never got around to working into the drivetrain.
The enclosure is held to the board with 6 quick latch releases. The batteries were a series of LIPO that I didn’t think were healthy enough to include in this listing. In its last configuration, the board was setup with a loop key, which I will include, but the mount for it will need to be repaired. It has a light up LED logo in the shape of a bird (which you can change by stripping the paint there and re-masking in your preferred style).
Again, this is a used semi-complete. It’s been through various iterations, and it was once glorious, but now there are things on it that need to be repaired, refined, or finished. It needs to go to someone who wants to put it back together or split it up into other projects. It was a great ride and I’m sure I’ll miss just having it around just to look at.
Looking for $1500 plus shipping in the continental USA. Like I said, I’ve been out of the loop awhile. I’m sure I’ll find out if that price is off in the current market, but I’m not in a hurry. Hope to sell it as a complete and ship it to one person in one box, but if that doesn’t work out I’m open to eventually parting some of it out.
- 2017 Landyacht Evo 39.5’’
- 180mm Cast Ronin Trucks
- ABEC11 Evolve F1 107mm Wheels
- Hoyt St. Puck Remote and receiver
- Zealous Bearings
- 4X @marcmt88 Ronin Motor Mounts
- @Psychotiller Evo Enclosure
- 4X @torqueboards 6355 190kv Motors
- 4X BESTORQ 295-5M-15 Belts
- 4X @marcmt88 30t Acetal Delrin Wheel Pulleys
- 4X 15mm 15t Steel Motor Pulleys
- 2X Ollin Board Co. 4.12 Vescs
- 2X ESCape
- Jhon Takenaka 3d Printed Evo Carry Handle (Shapeways)
- 2X @mmaner 3d Printed Phase Wire Guides (Thingiverse)
- Jhon Takenaka 3d Printed Evo Tailguard (Thingiverse)
- 5 Degree Wedge Risers Front and Rear
- Viscous Grip Tape
Extras
*4 X Metroboard Pulley Insert for Abec-11 Flywheels: 83 mm, 97 mm, 107 mm
*Skate Tool
*A lot of belts
*Some Risers
*Some idler bearings
Price (USD): $1300
