Ok I have done a first test ride. However I can’t tell if the range is better or worse. For this I’ll need to do another test drive as suggested.
However I can already say:
temperature measured with a infrared thermometer after a mix of steep climbs, carving and straight speeding:
12t @20° C ambient temperature = 49-50° C
20t @25° C = 50-54° C
12t breaking = belt slip
20t breaking under similiarly loose belt tension = no belt slip
12t also causes higher rolliing resistance than 20t by a lot. Therefore pushing the board is a easier with 20t.
At the same limits for bat and motors 20t reauired full throttle to get up a steep climb while speed was dropping. 12t still allowed for slight acceleration up the same hill with full throttle.
Sidenote: when carving at 15-20km/h it was harder to maintain a consistent speed with 20t compared to 12t.
One more thing: could it be possible pulley size has an effect on handling when carving?
I feel like there was more reluctance to get into a smooth carving motion.
My theory: in each corner a lot of friction is generated between rubber and road by lateral forces. When you get into a corner speed decreases under constant throttle input. The rear wheels now have more leverage towards the motors because of the bigger pulley.
Therefore I imagine the motor rpm drops further and speed decreases more than with a smaller pulley and changing the feel of the board in corners.
I don’t think so, because the reason rolling resistance is reduced is the same reason why it takes more energy to climb a hill. It’d balance out with the increased energy going the other way to accelerate with a worse ratio.
That’s probably a small part of it, but the main part is gearing disadvantage. Let’s just say 10T vs. 20T, each wheel rotation would need to spin the motor twice as many times on the 10T, which would create twice as much resistance.
There’s been some discussion about KV and gearing in the past, I think it came down to a tradeoff of copper losses and iron losses due to the thickness of the windings, and it probably doesn’t matter too much, although that was from a quick skim and you’d have to read deeper to figure out the answer.
This is turning into a potentially expensive experiment.
You could use a Flipsky 7070 110kv motor (rated to 100amps / 55ohm) paired with 24t motor pulley. Larger pulley if available?
Advantages:
I’d expect 12s on 110kv to be very quiet
Less rolling resistance, due to less belt bending, and as you pointed out - the gearing advantage with lower kv motor. I also don’t think the belt bending is trivial. People notice large differences in drag when moving from 10mm to 15mm belts, and that is purely due to belt inefficiency - not gearing disadvantage.
you could possibly run skinnier belts without shredding them, because you are engaging more teeth with the smaller pulley.
No need for an expensive test or changing belts or pulleys… do 1km on a flat track at constant 20mph with 80mm wheels, and another with 100mm wheels.
The 100mm wheels will require 25% more motor current to maintain constant speed with an associated 56% increase in motor heating.
The same useful work + the additional heating with the 100mm wheels will lead to a decrease in range, and an increase in watt hours per mile.
Use a GPS speedometer app on a phone so you don’t have to reprogram the speedometer when changing wheels so you can do a steady 20mph for both tests.
Since the motor will be turning slower at 20mph with the 100mm wheels, the motor torque and motor current will need to be higher, because useful work is torque multiplied by the angular speed. Less angular speed requires more torque (and motor current and heat) for the same useful work output. Yes, this ignores iron loss, but the motor won’t be turning faster than 8.6k rpm in either case, so the iron loss will be negligible compared to the copper winding loss in both tests.
I think that’s too many variables to be useful in a scientific experiment. Coupled with ride style, intended average speed, max speed, and terrain, it’s hard to make sweeping generalizations on how to optimize for a particular situation.
I believe you’re neglecting energy used for acceleration, which would be greater in a lower torque setup. Sure you save efficiency in rolling resistance, but you will likely use all that energy saved on acceleration.
Using the 3d servisas calculator for both scenarios:
110kv / 24t pulley = 34.1 mph loaded, Total max torque = 31nm
190kv / 14t pulley = 34.3 mph loaded, Total max torque = 30.7nm
The only downside I see is that the low Kv motor has 55 ohm resistance, but I’m not sure that’s really much higher than other large motors commonly in use.
I think this is a better belt drive setup. I don’t see any downsides, other than it’s $400 that would probably be better spent on moving to gear drives. If I was building a 12s board from the ground up, I’d try this.
Changing two variables at the same time (ie motor and gear ratio) will obscure the results because you won’t be able to attribute the change in efficiency to the change in pulley or change in motor. For useful results you can only change one variable at a time when doing comparisons. Besides, the motor size will also affect the results, not just the KV. That’s because a larger motor can use thicker windings to get lower electrical resistance. Also you could have 2 different motors of the same KV and the same can size, but one can still be worse than the other, because the resistance could be higher in one than the other (both motors could use the same can, magnets, and number of turns, but one might use thinner gauge wire than the other, leading to higher electrical resistance, and so more heat/loss for the same motor current, torque and rpm).
The rolling resistance isn’t low but that’s due to the terribly inefficient rubber wheels. Yet to try it on thane, but I do want to some day. With that said, when freespinning the wheel in the air (with the belt on of course), it actually spins a fair amount. Free spin was definitely better without the idler though. With that said, my guess would be that my wheels are so inefficient at least in summer time (35-38C), that it matters a lot more than the resistance of the belt.
Can’t compare to 190KV from experience sadly, as I haven’t tried 190KV motors yet. Can only write down the theory.
Everything below is assuming your ESC can supply any reasonable KV motor with the maximum current the motor can handle without thermal throttling. If your ESC thermal throttles before your motor, then going lower KV is 100% the right choice. Higher KV is harder to run for the ESC at the same performance level.
My take on which KV to take very much depends on riding style, and be ready because this is gonna get complicated. The two main types of energy losses in the motor are copper losses and iron losses. Copper losses are I^2*R, iron losses are much more complicated and increase with the rotational speed of the motor. This means, that when accelerating hard all the time, copper losses are high, so a higher KV motor with the appropriate gearing makes more sense. When the motor is spinning at a relatively high RPM most of the time, but there are mostly mild accelerations, then a lower KV with the appropriate gearing makes more sense.
Copper losses decrease quadratically as KV increases, while iron losses increase quadratically as KV increases.
Basically balancing out these losses doesn’t affect range a whole lot. Yes it affects it, but it’s not super drastic. I imagine maybe 5-10% at most. Where this matters a lot is motor temperature. Keeping the losses balanced ensures that the motor doesn’t overheat as fast.
Now, this paragraph I am not 100% sure about, so someone please correct me if I am wrong. Copper losses are I^2*R. Iron losses can be calculated for a set speed at BEMF voltage * no load current. This is what I am not 100% sure about. Anyways, I found a source for it at least and it makes sense to me Compare Equal Size Brushless Motors with Very Different Kv's - YouTube
But if that’s right, lets take a Maytech closed can 6374 motor, and compare 190KV vs 150KV. Let’s run both at the same current level, for example 70A @12S, I think that was common for these motors. Shout out to @rusins for the data!
190KV:
Copper losses at 70A = 70^2 * 0.014 = 68.6W
Iron losses at full speed 12S = 50.4 * 1.74 = 87.7W
As you can see, spinning the motor at max speed actually generates more heat than pumping 70A through it.
Copper losses at 70A = 70^2 * 0.032 = 156.8W
Iron losses at full speed 12S = 50.4 * 0.95 = 47.9W
Now lets throw the Flipsky 6384 motor in the mix as well, as that’s the most popular motor people seem to run nowadays. Lets look at the losses at 80A 12S. Sadly there is no 190KV data for this motor though
Copper losses at 80A= 80^2 * 0.017 = 108.8W
Iron losses at full speed 12S = 50.4 * 0.88 = 44.4W
This is a rough extrapolation that I made from the Maytech 6374 closed can 150KV and 190KV data. Calculating with 12S 70A. ((Total loss = copper loss + iron loss))
Now, I think the best is to have the copper losses higher than iron losses for street riding with not many hard accelerations but a lot of high speed riding. For this specific motor, somewhere around 140KV does make sense for this style of riding. If you only accelerate hard once, then hold speed at 30A per motor lets say, then a lower KV does make sense. @30A the copper losses are minimal, and with the lower KV, iron losses are minimized.
As for aggressive street riding and high speed hill climbs, I think the sweetspot is around where the iron loss and copper loss intercepts each other, maybe very slightly below. That’s around 170-180KV according to the graph.
As for hard offroading and track racing with a lot of sharp turns, having the iron losses very slightly above the copper losses or at the same level is the way I would like to go when the graph’s main parameters are the max voltage (so max speed) and max current. 180-190KV according to the graph.
PS: These calculations were made with the Maytech 6374 closed can because that’s the most relevant motor with data for at least 2 KV variants. The Flipsky battlehardened series motors, 6374 and 6384 in particular have much lower internal resistances, so with those we can go even slightly lower KV.
Also sorry, this has become way too long, lol
All measurements made with a Stormcore 100D which should be one of the more accurate ESCs in this regard. But at least the results should be comparable.
Hmm, I actually have a set of 190kv 6384 flipsky motors on hand, I guess I could quickly gather the data for them while I have them new. Actually nah they’re already mounted to my drives, I ain’t messing with them now, sorry
At least during acceleration at 80a, total losses bottom out at 190kv, max motor rpm.
Assuming constant speed, constant current should be significantly less than 80a. Assuming a lower constant current I expect total losses still minimized at max motor rpm, but a perhaps at a lower kv.
In general this shows the motor is most efficient close to its top rpm assuming you don’t go over 190kv or 12s.
Motor losses being minimized at max rpm correlates with peak efficiency when the top speed of the motor is geared for your average cruising speed.
Yes, the VESC motor detection numbers often aren’t very accurate, are affected by firmware version, and can be off by small amounts, large amounts, or double or half amounts.
Can we really derive iron losses from no load current?
Imagine spinning a motor on a bench and then spinning the exact same motor with bearings replaced to full contact seals; no load current will go up while iron losses aren’t affected at all.
For that reason accurate KV measurements spin the motor with a known RPM and measure the voltage and not the other way around.
I don’t know any, but if you know any and someone measures its resistance and no load current, I can compare it
That’s what I am thinking, even if it has error, so long as the data is measured on the same HW and FW the error should be consistent.
That would be interesting to see. Different sized pulleys, different center to center distance motor mounts, and idlers all effect how much the belt bends and therefore affect the no load current too. The only issue is that belt tension has a huge effect too on the measurement, and it would be very hard to achieve consistent belt tension for consistent results.
No. Its the sum of the iron losses and the mechanical losses inside the motor. But it doesn’t matter much, because both losses increase with speed, and both losses create heat inside the motor. With that said I don’t think mechanical losses are nearly as high as iron losses.
