Small (around 165mm) tires that will stretch to 65mm?
Anybody know of a tire with < 8" diameter that will stretch to 65mm wide? I tried the 165mm Trampa Urban Treads which are 45mm and they are too narrow. The profile of those tires is particularly round and rubber is quite thick and stiff. I could also go a bit larger on the tires if need be.
meepo cyclone racing or tubeless are good option
I think Land Surf has something like that too
Thanks. Unfortunately I already have wheels and even if I didn’t, I don’t suppose you know if those wheels are MBS bolt pattern?
Thanks. Yeah I see these: XCELL™ RS™ E-Skate Tires 165mm x 62mm - set of 4 - Land-Surf, LLC.. Not available right now but they certainly fit the bill. I’ll write to them.
u can just get the tire if u want
or
iirc they are verrrrrrry close to mbs @ShutterShock i think u know?
Thanks. I’d have to run tubes in them as I don’t think I could convert my existing rims to tubeless.
both tire works with tube as i’ve tested
I just bought a set of these to use with newbee pentagram v2 hubs. I’ll report back when I have some miles on them if I ever finish building my race board :grimacing:
Awesome. I just ordered a set and I’ll be running them on Pentagrams too.
If anyone has pics of those Linnpower 165x72 tires inflated, I’d love to see them. If the contact patch stays as wide as the tread, I may need to order a set for myself.
not if i put on miles befire you!
just inflate til the profile is flat, ez pz
use 150mm tubes
or just run them flat :rofl:
You don’t think 165mm tubes will work?
They fit MBS pattern as far as I’ve seen
They definitely round a little when inflated. IMO this is a good thing because it gives you a comfier ride compared to a totally flat tire like xcell rs.
If you want flat and comfy, bkb is a good option but don’t try to use them with wide rims.
Check out some of the pics of my raceboard on Instagram @rbe_motion, they are nearly flat but have a very small round to em. Pretty great for all around tires I’d think, but I only use them for racing so it’s hard to say
If this is what they look like fully inflated, then I need a set:
Ryan Berardelli (@rbe_motion) | Instagram
Ya that’s it. This is the tubeless variant, idk if they look different with tubes in them. I think this was around 30psi at the time
