Short ride with the plastic motor gear @jack.luis i was not able to pull more then 100amps motor…just too much torque lol, maybe il try to get the go pro on there so I don’t have to hold anything and do another video
Damn that thing is quiet!
Wow that sounds really good
Only hearing the electric whine of the motors is so cool
Best rim system ever, the Finality system is very intuitive.
That gear, tire and wheel combo is a fine balance between Torque, stability and absorption of road imperfections.
No need to balance that wheel and tire combo neither
What is that? Damn those motors are so close
looks like an FX steering damper, usually for motorcycles… can this be used for our application??
Yup. Etoxx has been doing them awhile. 3ds designed an adapter not to long ago.
Some other folks use the other style one
That drivetrain looks familiar
Yes can be used on ESK8 and 3ds came make them for Finality
It would be a bigger difference if I didn’t already have the hardest bushings on in the outer positions lol
Il move them in and do another video when I have time
your going to need their softest bushings or kaly ones to notice the differences
Well it’s actually pretty noticeable while riding, I think I am going to keep the set up as is. I like the stability
Il try to throw the go pro on the back and do like a uturn on both most extreme settings. Pretty neat little thing
I tried one briefly on hyper trucks it’s noticeable. But I heard those bushings are very hard for what they are. I guess size difference helps
How is that damper setup mounted, and are there only adapters for specific trucks or? Looks a hell of a lot cleaner than how heath lewis did it haha.
Damper is mounted a little adapter that mounts to the Finality truck and then a plate underneath.
This particular setup is only compatible with finality truck
[quote=“Skyart, post:861, topic:53679”]
interesting method of connecting the damper to the hanger. Is that a thermal press fit (or normal press fit) or is that just a very close sliding fit?
Very close sliding fit
Is this a one-off or will be available from 3ds?
