Okay… it’s been awhile since I made a build thread, and my last two were never completed. Big F.
This will be my first build where I build the battery myself.
Goals.
*I want something I can ride all year round in PNW weather (it’s wet. Like really wet)
That means waterproofingand water resistant is extremely important. I’ll be poking @b264 for is secrets.
this ^^^
is part of the reason I went with a top Mount enclosure. Plus these first gen Eboard solution decks have an extremely thin enclosure that I would definitely brake and it would never fit a 12s10p of 30q let alone 40t.
*My fastest build yet was 39mph so that’s the minimum on this thing.
*eventually want 4wd. Eventually
because ^^^^
- I’m a bigger guy at 200lb
- I’m surrounded in every direction by multiple long steep Hills. There’s literally no avoiding them.
- I’ve ridden a lot of other people’s board’s. I know how different setups feel. Every 2-wheel drive board I’ve ridden leaves me wanting more.
- I’ve got a 10p battery, so why not lol
It will be 2wd at first, so who knows maybe I’ll be satisfied. Maybe.
parts
Deck - @EboardSolutions first gen deck ( @Sender ised )
Trucks - @MBS oil slick matrix ll
Wheels - rockstar / rockstar pros
Pulleys - basic 72t ones off mbs site for now
Esc- @kevingraehl unity ( dont Lynch me lol )
Heating - from @surfnacho
Motor’s - @torqueboards 6380 190k
Battery - 12s10p 40t
Bms - well get to that
Case - amazon special
Remote - puck with @DRI Bruce Casemail
so far
I haven’t done much yet.
First I put the board together so I could roll around my driveway.
Turns out my pro hubs had a slight QC issue.
But mbs was cool and sent another ( just not here yet)
So I’m rocking the plastic rockstars, kinda wanna hydro dip them.
https://www.amazon.com/Skulls-Roses-Hydrographic-Water-Transfer/dp/B06XBJ1WCT/ref=sr_1_14?dchild=1&keywords=hydro+dip+skulls&qid=1602692918&sr=8-14
Maybe after i get it running.
Then my motor’s showed up from Dex (48 hours after ordering! )
Realized there was a light clearance issue with the sharp edges on inside of motor mount and phase wires. So gave it a shave.
After realizing I’m not going to get oil slick motor mounts I decided to paint them to match the roses on the deck.
Then I got a file for mount bash guards from @EboardSolutions https://forum.esk8.news/uploads/short-url/cZxdMNwETHCML2WLyYrUfpiZQfh.STL
Fit first print, and tossed some reflective tape on there. Pretty happy with the outcome.
I also decided to print a puck puck Bruce Case for my remote.
https://forum.freesk8.org/t/puck-puck-bruce/265
I’m still learning with my printer but it came out pretty good.
I ultimately decided to ask @Venom121212 to print one just because I didn’t have the colors I wanted and I knew he would.
Next came testing all these cells. Opening 120 of these little box’s sucked lol
All good at 3.43
Next let’s glue those fuckers together
last thing i did that im not sure is gonna stay, i printed some sk3 motor fans/covers. i incressed the overall size by 10% and its a pretty good fit. i just dont know if they hurt or help the motors but i do like how they look. this was my first print. im gonna try changing some other things, not sure if theyll end up on the final version of this board.
https://www.thingiverse.com/thing:2747889
i used v3 FYI
Big thanks to @klaus79856 @DRI and @J0ker
links
https://electricboardsolutions.com/collections/kits/products/mountainboard-enclosure
https://electricboardsolutions.com/products/dual-mount-for-mbs-matrix-ii
https://www.mbs.com/parts/13240-mbs-rockstar-pro-hub-silver-1
https://www.mbs.com/parts/13231-mbs-rockstar-ii-hub-black-1
https://www.mbs.com/parts/12204-mbs-metal-matrix-ii-truck-system-oil-slick
https://www.mbs.com/parts/47072-mbs-wheel-pulley-htd-5m-72t-1
https://www.hoytskate.com/products/nylon-puck?variant=31808909836330
https://www.vbeltguys.com/products/420-5m-15-synchronous-timing-belt?_pos=1&_sid=9eecd594c&_ss=r
https://derelictrobot.com/collections/diy-supply/products/0-2mm-pure-nickel-8p-21700-p-group-tabs
https://derelictrobot.com/collections/diy-supply/products/fishpaper-21700-4p-ring-insulator-strips
https://derelictrobot.com/collections/diy-supply/products/fishpaper-100x70mm-adhesive-backed-sheets
(^^^^^ ill try to add to this as the build continues)
