I use one of these:
It’s worked great for me but I don’t see how it could work on a helmet with a visor…
I use one of these:
I bet they’ll have some motorcycle HUD at some point that will have this
i got my board back .Hooray!
HA! Due to a land slide a very twisty part of wildcat canyon road is closed to traffic! I GET TO USE THE WHOLE ROAD!!!
“Land slide.” Uh huh. Definitely not a guy dumping shitloads of dirt onto the road with an earth mover.
Speaking of earth movers I got flack for not cleaning the graffiti off mine. I think it’s bs
I do lots that is not in my job description. However I loaded 153 trucks in 8 hours straight no break . So I feel like I’m good .
I got a flat on my second ride with the new finality gear drives and trucks. I think they are 1" wider than my old set. There is not near as much rolling resistance with these. Im told they are oil filled as opposed to grease. Im surprised its not ATF in there. We did this change to see if we could reduce the thermal issues im having . I notice the reduced rolling resistance while riding,im adjusting . Props to Skyart for always turning my board around in record time…
im going out in a few minutes for a ride . Life is good
These are FAR esier to change wheels on than my old set
So so many flats lately ! GRRRR!!! I’m sure some of it is stupid on my part but I’m being careful and it’s like every ride now
Still getting used to the new drive set up, I’m slow
Pinch flat I think
Maybe it’s time try some BRPs
What’s zat?
Airless wheels by @MoeStooge BRP Airless Race Wheel – stooge raceboards
He also has more durable street versions. Might have to email them cause I don’t see the street versions listed.
That or have you tried slime/tire sealant?
I think 3DS also made some compatible wheel gears for the BRP wheels so, @Skyart should be able to hook you up if you’re interested
this sounds AWSOME!! @Skyart IS THIS A THING??? SAY YESSSSS!!!
crap now im hotter than bill ogling your grammy !
Yes it’s a thing, but you need a hanger with a 12mm axle… I think that tire on 8mm axles will be too much stress…but if anyone can test some stuff out…maybe it you ![]()
Radium is also coming out with a similar airless tire.
Patch that bitch and put it back in rotation. Also, use talcum powder on your tubes to avoid pinching. Long-time road bike tip.
SRB uses 10mm axles primarily, so I don’t think 12 is necessary.
