Has anyone got easy suggestions on how to seal hole in the enclosure from dirt getting in?
grommet…
Meh, grommets would mean having to resolder the anti spark switch connectors again. Although this would be the best solution, I was hoping there might be a lazier option.
I was thinking of sticking a small sheet of rubber to the inside of the enclosure, cutting an X into it and poking the wires through. Do you think that would be a viable option?
sugru.
If you are in a rush consider my emergency method:
I read holes and enclosure.
Paging @IndianGummy
man hot glue, silicone, epoxy sugru just think a bit
Thanks, just brought sugru.
Maybe you could slice the grommet open and wrap it around your wire, then push it in to the hole.
That’s ice cold, Taz.
I don’t know how to deal with these regular @Jumpman posts. You’re basically frantic at the moment
Jb weld? Worked well for my xt90 holder.
Paper and spit is my go to fix. I never run out of glue or paper either. If I’m worried it might be failing, i just pick up some litter and do my thing.
Why do I feel like I am strapped to an inclined table with some laughing psychopath in front of me?
Sorry I probably hadn’t explained myself properly in my original post.
I have another build which is a kicktail Arbor deck, 83mm wheels, single vesc & 6374 motor. I only have one battery and cannot afford to shell out for another one anytime soon, so I was looking for an easy/non-permeant solution to transfer the battery/electronics between decks as and when needed.
Believe it or not but I had already thought about using hot glue, sugru, JB weld and grommets. But having never used most of these material before, I was hoping for some advice on which would be best, or if there was another non-permanent solution that I had not thought about.
Thanks for all the helpful suggestions that were genuine, and for not making a noob feel mentally inferior for asking a simple question.
