Any updates on when first batch will ship?
how much power can these take?
They have shipped. We are waiting for tracking numbers.
Peak is 1kW each.
Now iām tempted to build a shorter board with thisā¦12s2p/10s3p with the Omakase deck. Only if i can find an enclosure for itā¦
I have the same questions? Not sure what to do.
Ask him too, heāll eventually answer
Did you include front wheels with them?
Also Iām guessing my neoboxs will be shipped separately?
If order front wheels it ship with neohub. For neobox second batch can ship this month.
Sorry friend no. Is for customer project first.
Cool! Thank you for the updates Jeff
looking forward to getting the esc and hubs in. Iāll only be missing a battery pack for my build after that
excited to try these out
Battery hookup has a deal on a123 lifepo cells, can make a nice 14s3p for $50. Unless youāre a lithium ion guy.
Jeff can you clarify? It looks like there is no locking mechanism to prevent the motors from spinning and wrapping the cable wires? It looks like itās friction fit?
Just kidding, it does look like it is friction fit from comments above. Iām curious to see how this will hold up in high vibration scenarios. Looks really nice though and I have high confidence!
It relies on a collet clamp, the same way that heavy tooling machinery holds bits. The act of screwing down on the axle nut presses a cone between the hub and axle so the frictional forces become stupid highā¦could get to around 50 to 100 N-m of torque to break loose, wheels get like 20 N-m on the high end so no worry in the slightest
Makes sense
My morning brain translated collet -> spacer
Bruh itās like 10amā¦how do you not know all your machining terminology at the top of your head already!?
Lack of coffee?
For the deck Iām using, Iām gonna have to get a custom flex pack built most likely. Iām using the Sportster and gonna get an @eBoosted enclosure once he is able to ship again
Great work @jeffwuneo
Can you advise the minimum recommended axle length these hubs?
These are designed for a standard truck axle length. Iām not sure you could go shorter than what they are designed for.
