Okay thanks, this kind sucks for my setup thought since I was planning on mounting it to a heatsink/mount which is attached to the enclosure. so If I want to unplug cables I have to take the heatsink off the enclosure and then unscrew the neoboxes from the heatsink just to get to the cables. Guess I’ll have do some thinking
Just saw again that xt60 was used. I’ll edit the top post because it says xt90
So it comes with xt60
CAN cable and usb-C cable correct?
Is XT60. For usb is micro USB for now but later we might changing to USB C. Cable is include with neoBOX.
I just remembered people wanting xt90 when we discussed what connectors for phase wires we use.
also referring to this :
we obviously have had the pictures of the neoboxes for a while where both are visible. Just went from memory here.
Some change needed so is better to keeping micro USB first for testing. Later we can changing to usb C.
on the v6 version I would agree that xt90 will be better (nothing wrong, just imo), or even more WO connector at all.
Can’t wait to see some setup and testing !
The neoBox looks really beautifull @jeffwuneo
For next batch we include xt90 for neoBOX 6.
I definitely have to swap to xt90 because my board is build around that. Luckily just a minor thing.
That would be my preference as well. But not everyone wants to break out the soldering gun to get their build going.
Is better for include connector because not all friend wanting to solder. Is hard to have too many option.
Well the phase wires need to have connectors soldered to them anyways so I guess you have to do a bit of soldering regardless?
Also @jeffwuneo can I check these ones that are out for delivery are the first batch/testers? And therefore if we break one testing them we can get a free replacement? Just checking that is still the case as I want to test these bad boys
But motor wires didn’t get connector right ?
ho sorry LW already say it !
First batch is send already. But second batch can be ready next month.
if ordered on March 5th, that’s second batch correct?
Haha. Good point.
No we buy connector already solder.
Yes friend.
Yeah what I’m asking Jeff is are those that are receiving today in the first batch and therefore are they in the tester batch?
Ah I guess I’m second batch… will have to be careful
Yes friend. First batch is for testing.
Testers are indeed in the first batch, all people in the first batch will probably recieve their neoboxes within a week or so.
