He ride around Shenzhen, not our factory.
It’s called sarcasm, Jeff
I not know this word friend, sorry.
No don’t be sorry haha
A good example is, imagine you arrive in London and say
‘’ oh look, it’s sunny! ‘’
That is sarcasm ![]()
No they are set by the chemistry. 3.65V charge voltage but they are somewhat tolerant to overcharge, unlike li-ion. You should still stop at 3.65V/cell
For neoBOX, this is 14S or so
This is actually irony. But hey, you tried! (This is sarcasm) ![]()
You truly do have the most powerful board on the market!
Thats funny, because it’s true!
English Lessons Below
Someone else needs to look up these definitions too i think…
Actually you can express sarcasm using irony, but irony doesn’t need to be sarcastic and sarcasm doesn’t need to use irony.
Best case of irony is a gas tanker running out of gas.
Or this real world example I saw the other day:
A sign for “the job store” that said “now hiring”
Is it tho? I don’t recall seeing your board ready to order anywhere.
Right, it isn’t yet. He claimed it and I confirmed. But wrong thread.
Mine are from mfg spec sheet.
A123 nominal is 3.6v but the spec sheet says you can charge to 4.2v if needed. Internets says this is mostly fine. Crazy cells…
These cells also lose some voltage off the charger. Under load they’re pretty much 3.3v until empty when the voltage drops off a cliff. It’s hard to check state of charge.
Hot off the charger with the 15s pack I try to go uphill a bit first thing.
I’ve seen some drv errors every once in a long while but notihng cooked
Naw mate.
LoveChild is the most powerful board on the market.
Because I said so, and I’m prettier.
So you sellling it? I’ll give you some rupees for it
Sorry I wasn’t aware that was part of the criteria.
