*SCAM ALERT* neoBOX open source Focbox variant (HW 4 and HW6 Design)
Beautiful and super sleek. I’m wondering, does the top half have to be off the vesc in order to connect the remote reciever and canbus ?
if only there was a thread dedicated to testing NeoBox v6 we’d be golden
:smiling_face_with_three_hearts:
Love you, thanks :joy::heart:
no drama i’m excited too, have to get back to work really looking forward to your findings tonight! have fun
Sorry friend for screw problem. Is just one screw or more than one? Screw is carbon steel screw but for production batch we change to torx head because I think maybe can be easy to stripping this head now. If use torx bit can unscrew stripped screw.
For solder, cable is dip to molten solder to tin end for soldering.
Just one screw, I’ll find a way to get it out :+1:
No more forums for me until I’ve ridden!
:wave:
listen mate, you better come back with a full report or me and you are gonna have a problem.
We’ll givem the ol’ 1, 2 if he comes back empty handed.
Can use torx bit to unscrew.
is it me or are the phase cables stiff coming out of the esc? like they’re soldered internally
It’s probably because they were dipped and the solder wicked into the cable too far. Simple manufacturing fix, could just be these boxes.
We will have to see what other ones look like that people receive
@jeffwuneo definitely a QC issue to be followed up on
I would replace the oversoldered ones, the issue being strand breakage under the silicone
it’s fine to ride right now, but long term could be an issue
What about the bullet connector being soldered to the pad directly and being held by the case? It is no worse than the screws that hold the PCB to the case, but it gives more room for wire fuckery and no risk of bad connections (even if there is a cold solder, just stick the iron in the bullet for a moment and call it goodd)
I’m pretty sure this was discussed some time ago, as well as doing that for the XT connector - Jeff wanted to do it like that but the community seemed to disagree with the notion of board-mounting the connectors
I would say there’s risk of damaging the PCB if you’re careless plugging/unplugging if the bullet is soldered directly to PCB
I’m coming to visit you as soon as this cronoa shit dies down. This board isn’t suited for long term use in my mind. Too many untidy wires etc
gtfo and ride bruh, bring back the metr log
lots of love
:joy::joy::joy:
DHL just called my cell phone, neoboxes have arrived!!!
