Used precut vinyl to mask it off. The design is meant to look like a traditional brush style
If you top mount it i will seriousy cry, its too beautiful to be topmounted.
Would have been ready today but the stormcore said goodnight. Have to wait for another ESC now, otherwise the drives are set up
Its so nice I would hate to even ride it, are those BN270 trucks?
Yep
Why is the rear truck angled like that?
im calling he put it to 0 deg for stablity
What base plates?
I think the rear truck is supposed to be rotated 180
If you left it to what looks to be 0 deg angle, it wouldnāt matter if it was mounted like a RKP right?
I guess, but on bumps the hanger will sink into the pivot cup a little, and then he will have a negative angle
Also I bet turning radius will suck, so heāll have to wedge it to a more sensible angle anyway.
inb4 the motors donāt fit in reverse
Was waiting for someone to call that out
it is set to 0 degree and so itās irrelevant what orientation the hanger is in, just picked this way for motor clearance. Turning isnāt as bad because now you have not much resistance in the rear and you effectively get alot of lean. That forces the front to turn quite a lot. The rear should allow ±5 degrees before it actually effects turning/stability so I wouldnāt worry about the bushing squishing etc
These are boardnamics adjustable baseplates
Whats the front truck angle? Most severe mismatch I have done was 30° rear, 65° front. Was pretty sweet.
Between you @Jaws and @EreTroN you guys are so fucking talented Your attention to detail and color combos are freakin beautiful this is definitely one of my favorite builds this year
This truck set up just made my mind explode.
I donāt even know anymoreā¦
Front is at 40, but I may take it to 50. Probably not further than that
Simply one majestic build. Itās going to be a esk8 weapon.
