RipTide Sports Pneumatic / Composite tire project
Although I don’t see why not, would make sense to run dual compound.
Yellow is APS 90a and the blue is APS 85a
The white is a UHMW spacer to allow the tire halves to flex like a radial tire
Kinda looks like a 2-Part sandwich but it could be solid and that’s the mold part line
oh I see the spherical bearing could be inserted from below.
They are related
5 part sandwich, two hub halves, two tire components, one UHMW spacer
I was talking about the bushing on the 3-Link trucks but wheel dissection is good too
I don’t discuss that… :slight_smile:
I know, Me and @kook are!
Gracias!
I was referring to the link connection, axle to board bushing…
OH gawd…the humanity
If you’re 6" and above the market is crowded. I’m always looking for smaller pneumatics in the 120-130mm range for urban use. It would keep the comfort and obstacle handling but regain some of the torque and range lost with 6" and above. Just my 2 cents, don’t know if that’s even possible!
Oh cool! Thanks Brad :love_you_gesture:t3: Can’t want to see how these wheels do!
When used as a powered wheel, do the Gummies have a mechanical lock to the wheel?
I’ve got some here. It’s friction.
Kevin, can you post some pictures of the interface? I would be concerned with the power we have as well as brakes, there is a chance to slip in the hub. Although pneumatics rely only on friction also. So is the tire undersized in diameter and oversized in width?
@Skyart. Borrowed my trampa stuff. How about I send you 4 and you return later
4153412281. Text me address
Not currently using the trampas, if you eant them back I can bring em down
Thanks Kevin, I would just need a wheel and a gummy.
