We make and sell many of these pcb for battery.
Can I buy 12S2P 21700 or 12S3P 21700 or 12S4P 21700 with integrated BMS from you?
5 posts were split to a new topic: Hummie 18650 Battery PCB
Are u still making and selling them?
Hey John-
Looks like you’ve been gone a while. Jeff Wu has stopped communicating with the buyers of all his products and looks to be on the run.
That’s what I thought. Thought maybe he might pop up unexpectedly.
Is bombing other sellers’ sale threads with ur stuff fine when they roll?
Yes. Consider any NEO thread open game now.
Neo got me further along with motivation to finish this pcb and get them made. It seems done other than should’ve added fillets to the edges and corners. A dumb mistake but other than that it’s a done design and got 20 boards made and they work well and will sell them at 20$ with the plug and 10$ more for nickel. So about half of what neo was selling for and these have much more copper and nickel.
Curious- what are you using for insulation between the cells & PCB?
My thoughts exactly.
I glue the cells to the pcb. I’m open to suggestions but at this point ideal is cells glued to pcb and cells velcroed to bottom of the box like this:
And kapton on each cell and the top
Hot glue? Silicone sealant?
At minimum I would suggest a layer of fishpaper (or PETG sheet) under any area where you have positive terminals as the soldermask isn’t sufficient and can short on the cell cans through wear from vibration. I don’t consider soldermask a proper insulator against cells alone.
I have used fishpaper + heavy duty adhesive neutral cure silicone, but I also reinforce/strap with Kapton & heatshrink so that the silicone & nickel aren’t the only things physically supporting the cells.
I use silicone. I feel this battery built w the pcb, at least this design, there’s a lot less stress on the nickel when the cells are being help n not the pcb.
And don’t know if u saw I did a conductivity/resistance test with the cells welded vs just taped w conductive paste under and just tape shows a bit better. Only 3 welded on everything but still. I’ll see the just-tape battery’s ohms after a lot of use and see
Still welded to the cell though. Tempted to try just tape there too. At least with these iron cells I can’t blow up. Or have magnets for holding to the cell too
You can experiment for yourself but no one would buy that.
Totally agree with this right here. It’s a drawback of any PCB based design, but often times we have packs being built without any frame with P-groups being held together with nickel, tape, & hope.
I’ve been using a combination of liberal silicone for dampening/adhesion of cells to the PCB (insulating the positive copper pours that run under cells) + strapping with kapton + heatshrink. So far so good, and this is similar to how Ernesto is building his production batteries in the Kaly 2,0 as well.
Think what most people completly ignore is that most cells, when put to the test, generate an significant amount of heat. Having them spaced is generally not a bad idea. Did some FLIR monitoring on a big cake of batteries(7S15P), with spacers and the heat developement towards the middle was just ridiculous. Pack was designed to deliver upwards of 2kW of contineuos power so losses really started to add up.
Now put that into no airflow enclosure with the cells glued together. Puts things into perspective.
Wait what the hell did I write. I mean if the cells are held and the pcb just floats glued to the cells I bet that is really durable. But this battery can be really fragile and I bet easily damaged if just squished in a box or held by the pcb. I think it has to be held by the cells.
