Was it hot out at the time? I suspect your motor overheated. Mine have shut off when it’s really hot out and I go up a steep hill. I think they shut off past a certain temp to preserve the motors.
Did you try touching the motors? I find mine get quite hot when doing hills, I could see temperature being an issue if it was hot out, but that may be a serviceable issue.
Pixhehexd did mention they were not hot to the touch which is interesting. When it has happened to me I could still touch the motor but it was pretty hot. For me I figured out after a few times of this happening it was on a hot day and going up steep hills is what caused this to happen.
Something to note is that I could still use the brakes but I can’t give any acceleration until I reset it and it cools down again or else the same thing happens again. It sounds like the same thing that happened IMO.
I have definitely had times where I couldn’t pass the three second test on the motors haha
Exactly. The motors are still hot so they just shut off right away again. Been there for sure and just had to wait a bit for them to cool off and take it slow after that.
Also to add… I have only had this issue in 2WD. Has not happened to me with 4WD
Well yeah not as much load in 4wd. We’ve had people cut the temp sensors before in the older boards but on the newer ones the temp sensors aren’t connected.
I don’t have temp sensors on my diy either, no point really.
this was at night, pretty chilly, prolly around 20 degrees celsius.
The motors weren’t feeling hot at all, like I touched them once before after a longer cruise and they were feeling hotter then.
Would be great if the kit would give a warning about the motors overheating because it’s a bit sketchy to just suddenly lose power without warning.
Could be a different issue
So a few comments and questions:
Questions:
2WD?
Wheel Size?
Comments:
- If you read previous posts on temperature sensors, you will see that the versions of the revel kits that have sensor wires connected seem to be better off with the sensor wires cut.
- If you have larger diameter wheels, your experience could be worse than average.
- I’m guessing temperature readings are taken at the core. So on a cool day, you might be feeling none of it at the motor exterior
- Jason Engineered the ESC to always provide brakes under all conditions including low battery, and overcharge. So its no surprise (to me) that you retained brakes after loosing the ability to accelerate.
That said, read my next two posts because the issue might not be your temperature sensors.
I had a second set of related comments…
I’m not sure how steep and long a hill needs to be to trigger a temperature sensor shut down. Maybe its not much and the temperature sensors are just a nuisance.
That said, I wanted to point out that if you live in an area with steep hills, you really should be riding 4WD. The reason is that steep and/or prolonged decents will recharge your battery at roughly 8x the wall charger rate.
Jason has done alot to the ESC to protect riders from sudden loss of power and to maintain brakes for riders in emergency circumstances. Even still, small batteries have limits and its hard to say what those limits are until its too late.
With a 4WD kit, you get the following safety benefits:
- double your capacity to absorb regen current
- each cell is under half as much stress in the face of strong or prolonged braking current
- the motor load and ESC load of creating regen current is cut in half
- you get redundancy for motor, battery and ESC.
So I don’t know how severe your terrain is. But if it is, think ahead and upgrade to 4WD because if the only thing you do is cut your sensor wires – that might have consequences.
So it could also be a BMS/battery triggered fault. That’s certainly a possibility for 2WD rider traveling steep hills. Larger wheels could be an aggrevating factor.
If the BMS detects an overcharge or over temperature condition in any of the cell groups then I believe the BMS will reduce power to the ESC. This allows the ESC to provide braking. The ESC is unable to provide acceleration until the BMS restores full voltage to the ESC.
I’m pretty sure that’s the way the BMS and ESC work together when the BMS detects a battey fault.
Note that the ESC does not get any advanced warning from the BMS and the BMS does not communicate with the remote. So this scenario would match up with the Remote not providing the user of any advanced warning of the partial shut down.
Just incase it sounds like i’m criticizing the Revel Kit for some kind of poorly engineered communication between the BMS and the ESC…that is absoloutely not what i’m saying.
I’m actually saying the opposite. It is standard across almost the entire esk8 industry for there to be zero communicaton between the BMS and the ESC. The typical scenario is that the BMS shuts down the power without any warning and the rider is suddenly totally helpless to brake.
Jason might be the only one in the industry to put together a system that maintains brakes in the event of the BMS detecting a battery error.
He did that despite the fact that they just don’t make a BMS that can communicate with the ESC. You will find a BMS that can communicate detailed battery condition information to a cell phone app. But so far, I don’t think you could find an example of that information being shared with a remote or an esc.
Even the highly computerized Onewheels have a Controller and a BMS that operate completely independently. The only comunication between the two devices is the positive and negative leads. The OneWheel BMS progressively chokes off the voltage if it detects a battery error. That gives the Onewheel controller about 30 - 60 seconds to decelerate and land the tail on the ground. That works out on flat ground. I imagine it’s not so great on a hill. Also not so great at top speed.
Hey @Pixhehexd
Any info to share? I pitched a few questions your way.
2WD with default wheels
according to google maps the uphill section was 1km long with 70m of elevation change, so roughly a 7 degree grade, should be well within the capabilities of the kit I feel like.
I live in a somewhat hilly area although my usual route doesn’t include a lot of intense elevation changes, and even when I did hit hills with my previous board(wowgo 3) it handled them just fine so didn’t expect to run into these kinds of problems with this board.
I get that the 4WD is superior performance wise but it’s also almost 2 times as expensive and heavier/less compact.
So, I see a few possibilities:
- Motor sensors as suggested
- Intermittent connection in the battery that temporarily knocked the battery down to a lower voltage
- If you had a full battery and hit an early downhill section it could have been a partial shutdown triggered by high voltage. This would be unlikely if you feel the entire trip was uphill.
- If one or more balancing leads is disconnected, then you may have some cell groups that are overcharged and some that are undercharged. So with total voltage in the correct range, the BMS could still be triggered with an error that would partially cut the voltage to the ESC.
- It seems unlikley that it was a normal low battery condition based on your explaination of nearly full battery and only 1 kilometer traveled on a 7% incline and 90 mm wheels.
@ShutterShock What are you thinking?
Gonna guess that the battery probably has a connection that vibrated apart and then settled again
You picked Option 2 which I agree has the highest probability.
Option 3 is less likely but still quite possible.
I’d like @Pixhehexd to do the same run a few more times but start the ride with a battery that is less than full.
@Pixhehexd,
You can deplete the battery to 3/4 by riding on the the grass. 50 to 100 feet should do it.
If you have the same problem recurr in one of your 1 kilometer runs then almost for certain, it’s an intermittent battery connection.
If you cannot reproduce the problem across a dozen test runs (starting each at 3/4 battery) then I bet your battery is fine and Option 3 would explain what you experienced.
I hope its Option 3 because that means you don’t need any repairs and won’t be without a ride while you wait for couriers.
Can you do a few test runs and get back to us?
Remember that if you live at the top of a hill, even a small hill, its a good idea to deplete your battery a little before you start off.
Yo, dumb suggestion to check but… Are your deck and/or baseplate warped / twisted ? Cause a random cause would be your trucks and deck are fighting each other to go straight and it becomes noticeable only above a certain speed?
I got the exaggerated symptom at lower speed on a drop deck (say 22-25kmh) and solved it by inserting a lateral angled riser on one side.
@pkasanda I got a question you might be able to help? Looking to remove the tiny screws on the inner can of Landwheel motors. Pretty similar to the Revel ones. Bolts are stuck enough to strip a screwdriver. Maybe glue or else in the threads.
Between the 3 decks that I tried probably not. Don’t think the baseplate is warped either. I get my new bushings and pivot cups this week in the mail so I’ll let you know how that goes.
The answer is here:
My cloudwheels finally arrived a couple days ago after there was a mis-delivery. I contacted Iwonder and I’m not sure who it was but they went out of their way to contact the distributor and get the package to my door. Very good customer support as they kept sending me emails and letting me know what was happening. As for the wheels I really like them. I feel like the silver surfer. I’m stealthy quiet and can finally go over potholes, small curbs, gravel & sand patches without slowing down too much.
Also, I can add to the remote not being accurate for speed. I was going 46km/h at one point on my gps but the remote said I was going 37km/h. Way off, and I had my wheel diameter set properly on the remote.
