Whoa looks good! Hopefully better than blue cags 85mm are too small for comfort when it comes to ground clearance and direct drives
I feel like a kid in a candy store - so tempting
Wow. In terms of wow factor those are right up there with the awoahmods wheels but probably a lot more affordable
Thatâs the XR battery Iâm guessing?
Yes it is
Letâs see what these do to the range on my 2wd setup.
Quick first impression, these donât feel âsoftâ.
They donât pass the squeeze test like the 110s do, but theyâll impress on the road.
Yeah a âsqueeze testâ is a good way to describe it. The blue caguamas pass the squeeze test better than these do
Be very careful in cold temperatures. Lithium battereis are more vulnerable to damage. Just damaged my onewheel battery on a cold day. I think it was my son that did it. I think he pushed the range on a very cold day. It could have also been me. I left the Onewheel in the trunk overnight, then tried to ride it the next day. Now I have to spend $100 on shipping back to the factory and another $200 on a battery. Never push any lithium battery beyond the first vibration alert, expecially in cold weather.
Fortunately the weather is abnormally warm in my part of the Bay Area. Thanks for the concern though.
Eyeseeyou got some new wheels bruv ![]()
They donât feel soft when squeezing it, cos I had the same feeling when I got them last time, the blue cags is much softer when squeezed ![]()
âChronic Wheel Squeezerâ lol
Noticeable loss in torque and braking and even though it was pretty cold already can see a couple miles shaved off the range but wow cracks and imperfect roads are a non issue. Even those yellow honeycomb esk8 death traps are not an issue. Was also able to go over train tracks at a slight angle. Smooth and enjoyable ride.
Looks great. Iâm tempted to try some I-Wonders. However, I already have the Torqueboards 110 mm âTorqueWheelsâ (formerly called âTB CloudWheelsâ) . These make the ride ridiculously smooth and vibration free. Iâm guessing the extra spongy characteristics of the I-Wonders would have a bigger impact on range. Let me know if you try both and if you have an opinion on whatâs better.
Iâm going to suggest to Jason & Flo that a future model of the remote have some sort of super torque mode that can be turned on for riders with oversized wheels. Torque that would be potentially dangerous for 90mm wheels but perfectly safe for 110 mm wheels.
Iâm riding with 4WD so there is pleanty of torque even with the larger wheels. But mathematically, its a 20% reduction in acceleration and braking power. Thats the %difference in circufernece between 90mm and 110mm. 4WD Kit brake force is perfect with 110mm. It would be great to have 90 mm acceleration with 110mm braking.
For the sake of clarity, these are two different wheels. iWonder=Cloud wheel.
Correct. And I just noticed that Torqueboards stopped calling them cloud wheels. Thats what they were called back in November 2019. Now they are called TorqueWheels. They have 78A durometer and even softer 74A durometer models. Mine are the 78A version and they are pleanty soft enough to eat up all the road vibrations and pot hole impacts.
So thanks for your clarification. I had not realized that TB changed how the wheels are named.
Yup, I own both versions as well as the iWonders, and I agree with you that the 78A is plenty soft. So much so that I find only a small difference with the 74A. The upcoming 72A, however, might challenge my perception. I will be getting those as well because I have a problem.
You know, I completely blanked that they used to be called that. BTW, I finally saw the Revel kit in person a few weeks ago, and it was impressive.
I find the barking to be pretty strong if not abrupt even on the 2nd setting. Iâd imagine theyâd be uncomfortable in a 4wd setup on the highest setting.
For my Cruising style, even with the 2-3+ mile range reduction, I think I could keep the cloud wheels on at least for my mini quarantine brakes.
Still need to try out these 100mm tbâs but the 110âs sound real nice too.
Might not be relevant since I have a 2wd set up but howâs the range with the 110mm wheels?
