I’m figuring out the build is more fun for me. I live in MN. Started the esk8 hobby when it got cold and I’m now up to 6 boards… AKA no riding.
12s4p evo
10s4p evo
10s3p ownboard
10s6p Klever
10s2p BKB single
10s3p BKB dual
It’s a slippery slope…
-Colton
b264
#84
That’s pretty cheap, congratulations .
Make sure you check all bolts and everything external at 1-2km and around 100km I would look inside the enclosure and check everything.
If(when) you use loctite make sure you let it cure the FULL amount of time
Thanks and 100% will do. I need to wait for good weather for a shakedown run then reinspect.
Great looking built. I will wait for your review on the battery. I also want to order 2 battery.
Thanks! I’m excited to see what kind of range I can get.
What are those bolts you’re using to secure the enclosure to the deck?
Can you share a link? Looks super clean!
Sebi
#90
Those batteries included a BMS in each pack right? How are you planning on wiring them up?
I just wired them in parallel for output, each pack is charged separately.
What length did you get for the screws? I actually have the same enclosure and would love this setup.
I did 20mm, but would recommend 16 or 12mm if you’re not running a gasket.
27.8mph top speed with 20+miles of range. Finally got to really test it out today. Solid board.
will you upload any film on board?
What would you like to see?
b264
#97
Film? Like for wrapping food?
