@City-Blade-101 you have a Onan X2 there?! ->
Me too, with two dead batteries
correct me if iām wrong but it seems like @Venom121212 circuit board is at least 20,202 xās better than Venom06 board
Justin - how man volts are you pushing through those LED strips?
12 volts via a buck converter
I donāt record too many of my rides, but the carver has about 10 cycles on the pack now and range is feeling pretty good, so I wanted to see how it was fairing. Itās a 12S2P 10Ah lipo pack, rode mostly up to between 25-30 with a lot of stop lights/signs and this ride took it from 4.08 down to 3.61, which Iām pretty happy with.
It looks like an automobile āframeā which they call a āskateboardā in the industry ā the thing they base multiple makes and models of electric automobile upon. Itās essentially the drive train. There are a smaller number of āskateboardsā than vehicle models.
Yeah, still riding them and they are still going strong for about 2 years of every day abuse(have more than just one, hehheā¦got two 4WD but one unit is broken now, bc my hanger broke and the motor cables ripped of the esc.
I know you have one, but you have the older bldc model right?
Ahh! That makes a lot of sense now. Also the scale is not quite apparent from that pic.
I donāt know it itās the BLDC ā¦ it is very silent when I ride
yeah them bldc are silent as well and them foc models are not to hear at all.
You can see it on the esc: if you have this kind of āfull battery break thingā installed (its a chip with two big copper parts pluged into the esc which i posted above ) then you have the newer foc mode model.
I know one thing, mine doesnāt have these weak truck, mine are more Paris style and very thick
hahahaā¦ the hangers on mine are pretty thick,too (onan uses all the same trucks on all models Though), but dropping down stairs and curbs every day, causes the breaking of mine. I think its the weight of the motors, that is pretty hard to handle for every 8mm truck. Im not skating nice roads, i like rough conditions and our streets and sidewalks are pretty rough, so the perfect playground for me. You just need to hit a curb with a motor mount and the hanger will break like a tooth pick.
š¼ļø Pictures and nothing else!?
@Bindings_McGee , You actually used the puck as a puck?! @hoyt guys (ladies), thatās some truth in advertising.
Was that artwork just available somewhere, or did you ask LY for it?
I took this photo from google and tinkered with it
No way! Did you try asking before though?
Edit: I see youāve added a lot of things to it, itās definitely not just a copy, damn
Good artists copy, great artists steal
Those pics are four different crash states of that single shell - Iāve landed directly on it/slid on it over 30mph at least 7 times now.
3rd or 4th crash knocked off a PCB resistor, though they knew this was an issue because of some weird shell alignment. Fixed in 5mins
4th or 5th crash broke the potentiometer coupler, also an issue they knew about and fixed
Latest crash, of the butt hurtening, finally left that tiny crack. Titebond III + clamp and itās like it never happened
