But I just noticed, surely this is illegal?!
All together looks amazing. Good choice.
Definetely speed wonāt be a problem.
I topped 58kmh with a 12s3p 30Q battery and 97mm wheels. You have plenty of room for speed in case you want to reduce the wheels diameter.
a flpsky dual would struggle to fit, a unity does. Maybe thatās for build #8 orā¦
I was kidding, if it works then why not
I think the picture is only there to show that the vesc6 doesnāt fit and he will use 4.12. Which are not the best to handle high amp as a lipo can do. That why I asked
ah my bad
Well at least thst was my interpretation
It is, youāre right (just to show, maybe I could use some more rubber/foam layer to win some mm and be able to use the V6 or ESCape !)
no unity for me, for now, and (never say never but) I guess I will not use it.
Got a Dual ESCape too ā¦ even bigger than the single or the v6.
The dual 4.20 almost fit (almost nothing to do to make it work/fit, just a few mm to mill), but itās shitty (no power, no fun),
here I guess single/dual is the best scenario.
It should be a temporary buildā¦ itās why Iām not doing a build-log for now.
How many build did you get !??
Well the dual 4.20 plus or the older one with mod to donāt should down should be ok. The only thing closer ti high amp vesc I see fit there is the unity unfortunately. But if it is temporary then doesnāt matter. Have fun in the mean while ths this the purpose.
@Pedrodemio niceā¦ the white lights imply the observerās v=skateboard while the red and blue suggest the skateboardās v=~0.999ā¦c from left to right.
@Pedrodemio with some resistive loops in your wheels you can decelerate when you reach your destination without using too much fuel. superconducting ones with a large circulating current might work even better, hence the necessity for large batteries.
@Pedrodemio an interesting relativistic aspect of this picture is suppose the board was traveling very close to the speed of light from left to right relative to the observer, and someone stationary to the observer had used a flashlight to flash white light towards this board before it wizzed past the observer-- at the same time as when you are āseeingā the red and blue spots, the board itself is already completely out of the frameā¦ & depending how fast the board was moving relative to the observer, the blue light photons could be energetic enough to ionize molecules in your eyeballs or camera.
Been using my Evolve 107s since late 2017 and have well over 1000 miles on mine and mine have not chunked or sliced like these. Hmmm
Itās not exactly linear & does not look like a split along any production line which due to pouring in a single go there is no delam that could occur, suspect something sliced it on runover
Unlucky really most likely, probably some superglue and move on
š¼ Pictures and nothing else!. finally received everything but i forgot to order BELTS!! damnitā¦
Congratulations dude!
Thanks!!
This looks like front wheel drive. Maybe the motors on the pintail end?
^^ you exactly tell me the same thing some times before!
it could be looking like this but it is not, itās pretty long and wide (I just keep this shape/design for the surf style look) even if duck stance style I should be easy even with 46EU foot size :
It should be easy after this wider one (on DKP plus around 9cm of risers!!)
