@Riako the esk8 historian FTW
Donât lose the wheel or screw though. That wheel can come in handy in future ESCs / accessories⌠like to control lights and horns and stuffâŚ
itâs safely tucked awayâŚ
Itâs @anon54720240 creation. He came over to Check wheel bite for Psychotillers new trucks. I didnât want to take mine off, so I helped mock up similar geometry. We later went to His shop. 240s with 3, maybe 4mm riser was good to go. 260s exists
Great looking build. What deck is that?
I have a few old hand planes that Iâve been restoring too! I havenât finished them because I get super distracted by every other project I have going on!!!
I hope so. Sooner or later Wanted to finish the Thanos first but the vaccum forming is holding me down for the moment
@Riako Lipos? that should be crazy good
Presumably TB diddies or are they Reyâs?
107mm? = 1 million kph, you can use your gif from above again!
I stopped reading after that, can you TL:DR for me, tkx
Exactly!
didnât catch that
yes, Iâm always the lipo user ⌠here with a tiny little one (100Amps max) ⌠12s 12Ah donât fit here Iâm stocked with my little 6 x 2s 5Ah 20c âŚ
yes Mad Furry DD !! 75kV (+60kmh under 12s ⌠for sure I will not use all that speed and set a good erpm limit to 50kmh max like on all my board), yes I was thinking about to custom them to 105, 103, or 101mm ⌠or even 100 maybe to help the DD a little bit⌠but 1st I will test them like this.
I need some ground clearance for the bad road here.
Might be a good application for those lipo pouches that people used to use in order to maximise space and maybe get another P in, that is if you need lipo, I think the variations of compression packs made by @Agniusm @mishrasubhransu & @Winfly are a sure-fire winner for li-ion
But I know you love the lipo bang & maybe youâre reusing packs
yes esactly !
In the next one, I should get enough space for any type of configuration ^^
(here dual V6, 2 x 6s 12Ah (splitted), external bms)
But maybe one day I will use li-ion cell,⌠I mean Lifepo4, but it will be some A123 26650 2.5Ah one, with some kind of custom NESE module if so
When funds allow there are 21700 high discharge packs coming on line, molicel p42a is the champ for discharge/capacity/heat
thanks. It is a super cheap budget build to complement the other budget one I made for my son. This is so he can ride with a friend. The deck was ÂŁ30 off eBay and is a no brand blank 42" drop through. I can dig the link out if you want. The whole build cost about ÂŁ400 or so, so itâs not exactly high end stuff haha !
My only goal is to keep up with the damn pictures. I let it go on the ghosted builders site and could never catch up. I honestly am not a fan of looking at a lot of picturesâŚ
Yes please!
here you go. Cheaper than I remembered !
