ohhh shit I didn’t give enough info.
18 tooth, 8mm bore, 15mm belt these are 16mm wide. Flanged both sides. No collar. No keyway. Two M4 grub screws.
I only really care that it has no collar, fits 15mm belts and is 18 tooth.
these are similar to the 16T 12mm no coloar keywayed ones i just got. I still need to list them, damn i’ve been busy.
12mm
If you’re ok to order in EU, isn’t it what you’re looking for (without Overhang) ?
what?
@Riako there is a cable Chanel integrated in the deck for the power supply to the esc box?
🖼 Pictures and nothing else!
Yes,
“Intégration du câblage électrique dans le deck au pressage” --> “Integration of electrical wiring in the deck at pressing”
Thx! Is there also an information about which size of wires pressed in? 10awg 8awg?
Nope, don’t know that ! Maybe will know, I’m sure he saw the deck alone, unmounted
All I have, translated by google, is this :
A deck modeled and designed by Overion in partnership with X’shape and Amadride, and hand-crafted by Master Shaper “Skully”:
Awesome futuristic design
Oversize dimensions: A much larger length than usual (developed greater than 110cm), and a foot width the largest in the world so far for a mountainboard deck (greater than 26cm)
Composition:
Ultimate version: Multi-ply sandwich made of wood, carbon and fiberglass, automotive grade varnish, different thicknesses to suit every customer.
Ultimate Pro version: Full carbon with high density foam core
*Integration of electrical wiring in the deck when pressing **
Pre-drilling for straps for all types of riders
Grip reinforced and expanded
Warranty 3 years delamination
Maximum weight of the rider in “high” version: 120kg
Interests: These decks have an intermediate flexibility between Trampa and MBS, with an ideal rebound at the end of the turn without any tangling; the full support of the heels and points on the deck allows to exert a total pressure in turn which generates an easy carver simply exceptional: it turns like skateboard or almost.
MBS F5 Straps delivered as standard
All informations here but french only, easy to translate however : https://www.overion.fr/produit/ultimate-overion/
Having all that weight at the ends of the board does not seem like a very good idea to me.
This increases the rotational inertia, making an already heavy and difficult to turn board of this type, even more difficult.
That is a pretty sweet trail. Yous is lucky.
Where is it?
Beautiful! What camera are you using btw? Footage looks really sharp, and the invisible selfie stick stitching is flawless!
I’ve been to the shasta dam. My grandparents live in redding and my mom is from McCloud.
Always a shit ton of driftwood being pulled out of shasta lake.
What is love? Baby don’t hurt me …
@professor_shartsis I sent you my love and appreciation, please respond
@rusins thank you… I hope you’ll understand that as owner of a photography company, the answer to your question is considered proprietary information.
i’ll bet it has a lens in it. You’re using one of those fancy cameras with a lens in it aren’t you… sorry i ruined it for you.
good for aerial…
