These light up the underground railroad ferrying escapees from you know where to the promised land. We try to keep you in the dark on such matters as you’re a known snitch.
If you are interested in making more, you should start a thread so we can learn about your design.
It is an official esk8 news handcasted candle, that I’ll sell
Single layer, just used the battery to put weight on the enclosure… Couldn’t wait, so quickly threw something together with another (dual layer) enclosure i had laying around (hence the straps and the protecting foam) :
I want one of those enclosures…that’s bad ass bruh…similar to my build
What’s the scent? Soldering fumes and weed?
Damn. And I forgot to black the cut edges on those enclosures… sorry. Sharpee should do the trick!
Could totally do that, but for now…
Yes sk8king is an awesome skate shop. Their turbo wheels are awesome with the aluminum hubs. And they do some nice mods.
I am working on a life test and if it meets the design requirements, I will post a post.
@rich
🖼 Pictures and nothing else!
Those wheels look soooo wide. Really seem to make a big difference with those hubs.
Like it!
You need to sacrifice 3 helical gears and 20sets of 8“ pneumatics to the god of gear drives…with a bit luck you will get something for Christmas than
The offset hubs are prototypes from E-Toxx which I’m testing
They are not available yet but you can prepare your wallet for next season
Yes
No just measured again, it looks more on the pic. The height of the left phat tire is 190mm, the 8" on the right side 195mm. So it’s 2,5mm difference in ground clearance but even less, max 2mm because the tire is worn, the other is new. Anyway I’m switching to 9" soon…
