What pulleys are those? What fits and what doesnt?
If I can keep using my 44t pulleys, I want a set of those bad boys
Standard Trampa pulleys and some 3d printed pulleys I found on thingiverse. I’ll see if I can find the link.
Sweet. I’m using unik 44t made for superstars
But the manufacturing tolerances on superstars sucks balls and gives me too much wobble and I dont wanna start fucking around with weights
@mmaner that’s a clever way to attach pulleys, wish I had thought of it when doing mine
How do you plan to secure them to the hub? Putting these wheels together is such a pain, specially when using threaded spacers
@Pedrodemio Are trampa pulleys not as simple as bolting the hub screws into them? Atleast that’s how mine from unik work. You just get rid of the nuts and bolt into the threaded holes
The black ABS are press fit. You add a bearing at the axles and then spacers to make up the rest. When you put the axle nut in place everything stays put.
Mine are 3D printed, I use a hex standoff, so I have one screw going from outside to the hex, and one screw going form pulley side to the hex, so 10 screws each wheels, and all of them need to be thread locked in place, and to make maters worse I made a notch in the pulley that is also a hex shape, so the spacers have to be perfectly oriented for it to fit
yeah, dumb design that I will change next time I print one
Only went this way because I couldn’t find screws long enough
Yes…tunnel risers were on sale. You know how it is😁
Step 2: helmet
Will start them off at $159.99
We talked about it already. Once we get past walking speed she’s wearing one
What gear drive is this?
Thanks! You can probably route the cables next to the mount between the back of the light and the truck plate.
really not sure what is being conveyed here? An esk8 news candle?
A beacon to light the way to new frontiers?
A gentle glow to warm the community heart?
Or I light it and burn the place to the ground.
What you trying to say bro?
HI, this is my own design, I made three sets.
