HobbyWing Max6 ESCs and a HK-GT2B.
See above your post.
weird that seems like should be a solid combo, IDK shit tho
@b264 would dual independent help against issue of signal hijacking?
That sucks. Failsafe is only to prevent your board from going full throttle, to a netrual. You would still lose connection⌠GT2B is pretty reliable though. By chance is the antenna near power/phase leads or carbon fiber?
In the area that you fall both times is there a traffic camera or a red light camera. I have seen those cause issues.
It happened close to a 5G repeater or tower or how ever itâs called.
Before any of you literals call out a video in the photos thread, itâs 5460 photos stitched together perfectly
I flagged it
Use dual receivers â and no CANBUS or Split PWM (âPPMâ)
Use the Mini and set the failsafes.
There is a certain spot around me where signal always cuts out no matter what remote or esk8. I canât stress how much the dual receivers help. Thereâs always a short time between when one signal drops and when the other signal drops. So instead of, for example, both motors cutting out simultaneously, and jerking you really hard, you have one motor cut 75ms before the other one and so the jerk you feel is half as big and half as likely to knock you off balance.
I know the felling man⌠It sucks.
I know the feeling too. Still donât know how to get out of the feeling but it doesnât matter now
If you use fusion I can correct the toolpath
Watch it on mute then, I didnât flag it.
Last year I had access to a CNC and tried learning. I donât have access anymore
Not all bad. I can let a machinist worry about my parts while I do other things
Of course itâs all about needs. If the goal is getting the parts then is more efficient like that
Ideal world is getting parts next day at a good price
wasnât complaining about your post & theres plenty of other animated gifs
It just doesnât sound right
Not even closeâ:grinning:
