Sound like it’s too much trouble…don’t worry, il take good care of em
Nice layup. Which materials and how are they sandwhiched?
Definitely savable, just a little work.
Waiting on your review before I pull the trigger
First impresson is that it is a great solution. The hypertruck bushings sit well in the mbs bushing seat and feel great. Feels more reboundy than the stock mbs bushing. Heaps of lean on these blue bushings. Probably need a step up in bushing duro actually. Also these anti sink are plates and ti bolts are a work of art.
I did stay up until 2am cussing a lot because I cross threaded and then stripped the head on one of the ti bushing bolts during install. This was 100% my fault. Luckily I have a vice (edit: vise) in the garage and i was eventually able to work out the cross threaded bolt and save the truck hanger. I basically bored a new thread in the m2 hanger. My advice would be when you thread the bolt initially, remove the hanger completely from the baseplate, and thread it in backward. Much easier to avoid cross threading that way.
Replacement screw and an extra is on the way - thank you @Tony_Stark !
Hrs the story? Did you crash or just started seeing the deck split apart?
Are you mad at him? Why does some random guy have to be peeing on him…
Also, deck looks mint!
@cfelzien
I just noticed it. I’m not sure when it started. Likely from all the riding at carve
Thank you man, i appreciate that!
Did you possibly over-torque the enclosure bolts? Happening right where the inserts are.
I snugged them down but didn’t crank on them by any means. TBH I’m not that worried about the deck. I just thought it was interesting that this could happen
@BillGordon you are 100% right. This is due to tightening them down too much. The gap reduced when I unthreaded the screws.
Do those bolts have any sort of spring washer? If not you could add some so you don’t feel the need to tighten so far down
The rubber part of the washer was disintegrating so i ripped them off. Apparently you need the height those give you for the bolts
You’re missing the weather sealing gasket as well by the looks
I think the gasket is just squished down to the point that it does nothing
That could be. You don’t want to crank enclosure bolts, snug and blue loctite will hold.
400gsm biaxial fibreglass
200gsm UD CF
Soric XF3
And Swancor 901 epoxy vinyl ester resin
It’s 8 layers of biax fg and 4 layers of cf, with three core layers in between. Arranged like a club sandwich some of the cf layers are rotated 90degrees
those inserts lacroix uses use half their height for the hex socket. so they have much less threaded length on them. This means the tolerance for a bolt that both catches the thread and doesn’t push out the other side to split the deck is very very small. and those rubber washers they ship with break down and basically reduce spacing allowing the bolt to push out the back.
it doesn’t help that the bolts are very hard to get to the threads given the enclosures desire to pull everything away.
Anyhow. mine is splitting too.
Are these kegel cored hubs? And what hubs are they? Beautiful!
Thanks man! They’re the meepo cyclone racing wheels. They come with pulleys that are already mounted to the hubs.
