Oooh Google lens finally got it on one of the stills specifically.
That’s the money shot!
You guys think we can put a bn270 on there somehow?
0,5, 35, 40,45 degree adjustable,
You can run 3 bushings, one on the rear hanger.
or just one on the kingpin, one on the rear hanger.
Turning on this truck are insane! This are not the maximum lean.
Here on street, 45 degree, bushing on loose position.
dang bro, this is some crazy shit
They do that here with tables at eateries with umbrellas, tissues, etc. It’s called “choping”
…looks up choping…
Hmm, methinks I misunderstood what type of “eatery” to which you refer to
Dirty, dirty Brian. Dirty.
Whoa! That’s like DKP but without being DKP!
Good luck man! I’m sure it’ll be a winner.
How thick of an offset did you do between parts?
The finished part should end up at 2mm. I really hope it’s thicc enough
otherwise 150hrs of printing down the drain.
Just built a timber frame for it and waxing up the mold now. It’s nearly go time!
Keen as to see the results Al.
If forging doesn’t work you could probably do infusion or transfer moulding in that also. (With some mods)
Make a DIY machine that chops fiber.
He is that machine!
