Sorry, I didnāt see any previous discussion. I thought the dispute was primarily about the firmware. Thanks for clarifying.
@3DServisas what controls the stoplight flashing function? Will it be compatible with any remote?
It is controlled by a modern receiver that has up to 4 controllable channels. Only compatible with two kinds (trigger and thumbwheel) of the new remote.
I really donāt get what all this drama is about. As far as I understand it @3DServisas has bought both fw and hw from an independent company? Whatās all this fuss about licensing then?
Fishing for compliments.
Both of you are beautiful.
Prrrrrrrrrrrrf this is so deplorable⦠my god. Why this ultra aggressive and disrespectful attitude?
How man thatās a gorgeous board ! How did you do the logo thing ? Itās all el isnāt it ?
We need a build thread for this beauty !
This skate looks like itās going to start yelling and try to upgrade me
Yeah, hahahaha, had problems with phase wires touching the receiver bc the rheostatic brake was added to the wrong position. The last rainy days i decided to rework the whole drives with new custom motor mounts, new plugs and pipapo plus a new surface, bc the frames were pretty beaten up.
I fthis is a hint to cut off the base plate section from the frame I can tell you this is an old idea for me
the only thing is it wouldnt make a difference for me so no reason so far.
Removed the tape for 1 second to check something and while tightening the too bus bar it moved down and make contact for half a second. All the groups still read 3.53V 42.40V for the pack. Am I still good?
Youāre fine, if you really want to check you can take the cells out and measure internal resistance but realistically, its burned up and sparking because there is a very resistive short, youād be worse off if it connected without sparks because youād be shorting unbottlenecked massive amperage
Iām sure you have figured this out now, but for anyone else reading, you should always insert both bolts before snugging up either of them.
6394 170kv? ![]()
6384 in 140, 170, and 190.
Also those 14T are technically in stock
Damn dude when can I buy a pair?
Iām riding 190s on my mountainboard but wanna up the torque!
And oooo Iāll let my cousin know, heās been trying to get some haha.
Edit: they say out of stock? Haha
If you want the motors, I can offer them you now through PM. Theyāre super easy to ship. Same goes for the pulleys. Iām done unpacking everything so itās shipping time
